Beam Design - 28111 Via Del Cerro - Deck
Design Span (L): 7.17 ft.
Clear Span: 7.08 ft.
Total Span: 7.25 ft.
Bearing (lb): 1 in.
Live Load: 53.3 plf
Dead Load: 26.6 plf
Selfweight: 14.0 lbs
Dist. Selfweight: 1.96 plf
Total Weight: 14.2 lbs
Beam Design Barbara Mcgahey 28111 via del cerro deck
10/12/2020 1
10/12/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (86.00 + 1)] x (12 in./ft.)3 = 0.42 ft3
Volumespan = N[A x L] = 1 x [8.25 x 86.00] x (12 in./ft.)3 = 0.41 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.42 = 14.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.41 = 14.0 lbs
53.3 plf
26.6 plf
ws = 1.96 plf
7.17 ft.
7.08 ft.
7.25 ft.
296.75 lbs
296.75 lbs
10/12/2020 3
fb = = 834.0 psi
 fb = 834.0 psi < Fbx' = 1345.5 psi  (CSI = 0.62)   ➜  OK
10/12/2020 4
fv* = = 46.51 psi
 fv* = 46.51 psi < Fvx' = 207.00 psi  (CSI = 0.22)   ➜  OK
fv = = 53.34 psi
 fv = 53.34 psi < Fvx' = 207.00 psi  (CSI = 0.26)   ➜  OK
10/12/2020 5
ΔLL = = 0.10 in.
(L/d)LL = 86.00 / 0.10 = 904
 ΔLL = 0.10 in = L/904 < L/360   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 86.00 / 0.15 = 589
 ΔTL = 0.15 in = L/589 < L/240   ➜  OK
Ab = b x lb = 1.5 x 1 = 1.50 in2
fc⊥ = = 197.8 psi
 fc⊥ = 197.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.32)   ➜  OK
10/12/2020 6
