Beam Design - 28111 Via Del Cerro - Deck
Size: 4 x 6
Design Span (L): 7.00 ft.
Clear Span: 6.75 ft.
Total Span: 7.25 ft.
Live Load: 86 plf
Dead Load: 43 plf
Selfweight: 32.0 lbs
Dist. Selfweight: 4.57 plf
Total Weight: 33.1 lbs
Beam Design Barbara Mcgahey 28111 via del cerro deck
10/12/2020 1
10/12/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (84.00 + 3)] x (12 in./ft.)3 = 0.97 ft3
Volumespan = N[A x L] = 1 x [19.25 x 84.00] x (12 in./ft.)3 = 0.94 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.97 = 33.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.94 = 32.0 lbs
86 plf
43 plf
ws = 4.57 plf
7.00 ft.
6.75 ft.
7.25 ft.
484.20 lbs
484.20 lbs
10/12/2020 3
fb = = 556.4 psi
 fb = 556.4 psi < Fbx' = 1345.5 psi  (CSI = 0.41)   ➜  OK
10/12/2020 4
fv* = = 31.66 psi
 fv* = 31.66 psi < Fvx' = 207.00 psi  (CSI = 0.15)   ➜  OK
fv = = 36.43 psi
 fv = 36.43 psi < Fvx' = 207.00 psi  (CSI = 0.18)   ➜  OK
10/12/2020 5
ΔLL = = 0.06 in.
(L/d)LL = 84.00 / 0.06 = 1404
 ΔLL = 0.06 in = L/1404 < L/360   ➜  OK
ΔTL = = 0.09 in.
(L/d)TL = 84.00 / 0.09 = 904
 ΔTL = 0.09 in = L/904 < L/240   ➜  OK
fc⊥ = = 46.1 psi
 fc⊥ = 46.1 psi < Fc⊥x' = 625.00 psi  (CSI = 0.07)   ➜  OK
10/12/2020 6
