Grade: 24F-V3 1.8E SP/SP
Size: 3.5 x 9.625
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Dead Load: 41 plf
Selfweight: 135.9 lbs
Dist. Selfweight: 8.63 plf
Total Weight: 138.1 lbs
Beam Design 2020A205
10/7/2020 1
d = 9.625 in.
A = 3.500 x 9.625 = 33.69 in.2
Sx = (3.500)(9.625)2/6 = 54.04 in.3
Sy = (3.500)2(9.625)/6 = 19.65 in.3
Ix = (3.500)(9.625)3/12 = 260.07 in.4
Iy = (3.500)3(9.625)/12 = 34.39 in.4
10/7/2020 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [33.69 x (189.00 + 3)] x (12 in./ft.)3 = 3.74 ft3
Volumespan = N[A x L] = 1 x [33.69 x 189.00] x (12 in./ft.)3 = 3.68 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 3.74 = 138.1 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 3.68 = 135.9 lbs
Distributed Self Weight (ws) = = 8.63 plf
41 plf
  ws = 8.63 plf
15.75 ft.
15.50 ft.
1197.04 lbs
1197.04 lbs
10/7/2020 3
fb = = 1030.3 psi
 fb = 1030.3 psi < Fbx' = 2400.0 psi  (CSI = 0.43)   ➜  OK
10/7/2020 4
fv* = = 47.12 psi
 fv* = 47.12 psi < Fvx' = 300.00 psi  (CSI = 0.16)   ➜  OK
fv = = 52.47 psi
 fv = 52.47 psi < Fvx' = 300.00 psi  (CSI = 0.17)   ➜  OK
10/7/2020 5
ΔLL = = 0.30 in.
(L/d)LL = 189.00 / 0.30 = 639
 ΔLL = 0.30 in = L/639 < L/360   ➜  OK
ΔTL = = 0.44 in.
(L/d)TL = 189.00 / 0.44 = 427
 ΔTL = 0.44 in = L/427 < L/240   ➜  OK
fc⊥ = = 114.0 psi
 fc⊥ = 114.0 psi < Fc⊥x' = 740.00 psi  (CSI = 0.15)   ➜  OK
10/7/2020 6
