Beam Design - 231 Bay Ridge Parkway
Design Span (L): 29.75 ft.
Clear Span: 29.50 ft.
Total Span: 30.00 ft.
Live Load: 40 plf
Dead Load: 6.7 plf
Selfweight: 238.5 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 240.5 lbs
Beam Design Jason Glenn 83 Woodhull St. 112
10/7/2020 1
10/7/2020 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (357.00 + 3)] x (12 in./ft.)3 = 7.03 ft3
Volumespan = N[A x L] = 2 x [16.88 x 357.00] x (12 in./ft.)3 = 6.97 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 7.03 = 240.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 6.97 = 238.5 lbs
40 plf
6.7 plf
ws = 8.02 plf
29.75 ft.
29.50 ft.
30.00 ft.
820.75 lbs
820.75 lbs
10/7/2020 3
fb = = 1147.9 psi
 fb = 1147.9 psi > Fbx' = 900.0 psi  (CSI = 1.28)   ➜  NG
10/7/2020 4
fv* = = 33.89 psi
 fv* = 33.89 psi < Fvx' = 180.00 psi  (CSI = 0.19)   ➜  OK
fv = = 36.17 psi
 fv = 36.17 psi < Fvx' = 180.00 psi  (CSI = 0.20)   ➜  OK
10/7/2020 5
ΔLL = = 1.24 in.
(L/d)LL = 357.00 / 1.24 = 288
 ΔLL = 1.24 in = L/288 > L/360   ➜  NG
ΔTL = = 1.69 in.
(L/d)TL = 357.00 / 1.69 = 211
 ΔTL = 1.69 in = L/211 > L/240   ➜  NG
fc⊥ = = 91.2 psi
 fc⊥ = 91.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.15)   ➜  OK
10/7/2020 6
