Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Live Load: 20 plf
Dead Load: 20 plf
Selfweight: 42.0 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 42.8 lbs
Beam Design 2020A203
10/6/2020 1
10/6/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (153.00 + 3)] x (12 in./ft.)3 = 1.25 ft3
Volumespan = N[A x L] = 1 x [13.88 x 153.00] x (12 in./ft.)3 = 1.23 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.25 = 42.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.23 = 42.0 lbs
20 plf
20 plf
ws = 3.30 plf
12.75 ft.
12.50 ft.
13.00 ft.
281.42 lbs
281.42 lbs
10/6/2020 3
fb = = 493.6 psi
 fb = 493.6 psi < Fbx' = 1138.5 psi  (CSI = 0.43)   ➜  OK
10/6/2020 4
fv* = = 26.23 psi
 fv* = 26.23 psi < Fvx' = 207.00 psi  (CSI = 0.13)   ➜  OK
fv = = 29.84 psi
 fv = 29.84 psi < Fvx' = 207.00 psi  (CSI = 0.14)   ➜  OK
10/6/2020 5
ΔLL = = 0.08 in.
(L/d)LL = 153.00 / 0.08 = 2037
 ΔLL = 0.08 in = L/2037 < L/180   ➜  OK
ΔTL = = 0.16 in.
(L/d)TL = 153.00 / 0.16 = 941
 ΔTL = 0.16 in = L/941 < L/120   ➜  OK
fc⊥ = = 62.5 psi
 fc⊥ = 62.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.10)   ➜  OK
10/6/2020 6
