Grade: SPF SS
Size: 4 x 16
Design Span (L): 20.75 ft.
Clear Span: 20.50 ft.
Total Span: 21.00 ft.
Selfweight: 229.5 lbs
Dist. Selfweight: 11.06 plf
Total Weight: 232.3 lbs
Load Duration: 1.33
Orientation: Horizontal
Beam Design 2020A202
10/5/2020 1
d = 15.000 in.
10/5/2020 2
= 30.34 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (249.00 + 3)] x (12 in./ft.)3 = 7.66 ft3
Volumespan = N[A x L] = 1 x [52.50 x 249.00] x (12 in./ft.)3 = 7.57 ft3
Total Weight (WT) = ρw x Volumetotal = 30.34 x 7.66 = 232.3 lbs
Self Weight (WS) = ρw x Volumespan = 30.34 x 7.57 = 229.5 lbs
Distributed Self Weight (ws) = = 11.06 plf
ws = 11.06 plf
20.75 ft.
20.50 ft.
21.00 ft.
1953.63 lbs
1953.63 lbs
10/5/2020 3
Fby' = (1250)(1.33)(0.85)(1)(1)(1)(1.1)(1)(1) = 1554.4 psi
fb = = 3923.8 psi
 fb = 3923.8 psi > Fby' = 1554.4 psi  (CSI = 2.52)   ➜  NG
10/5/2020 4
Fvy' = (135)(1.33)(0.97)(1)(1) = 174.16 psi
fv* = = 53.60 psi
 fv* = 53.60 psi < Fvy' = 174.16 psi  (CSI = 0.31)   ➜  OK
fv = = 55.15 psi
 fv = 55.15 psi < Fvy' = 174.16 psi  (CSI = 0.32)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1500000(0.9)(1)(1) = 1350000 psi
10/5/2020 5
ΔLL = = 5.77 in.
(L/d)LL = 249.00 / 5.77 = 43
 ΔLL = 5.77 in = L/43 > L/360   ➜  NG
ΔTL = = 10.73 in.
(L/d)TL = 249.00 / 10.73 = 23
 ΔTL = 10.73 in = L/23 > L/240   ➜  NG
Fc⊥y' = (425)(0.67)(1)(1) = 284.75 psi
Ab = d x lb = 15 x 3 = 45.00 in2
fc⊥ = = 43.4 psi
 fc⊥ = 43.4 psi < Fc⊥y' = 284.75 psi  (CSI = 0.15)   ➜  OK
10/5/2020 6
