Design Span (L): 4.55 ft.
Clear Span: 4.30 ft.
Total Span: 4.80 ft.
Live Load: 800 plf
Dead Load: 300 plf
Selfweight: 31.1 lbs
Dist. Selfweight: 6.83 plf
Total Weight: 32.8 lbs
Incised Lumber: Yes
Beam Design 2020A191
9/17/2020 1
9/17/2020 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (54.60 + 3)] x (12 in./ft.)3 = 0.92 ft3
Volumespan = N[A x L] = 2 x [13.88 x 54.60] x (12 in./ft.)3 = 0.88 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 0.92 = 32.8 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 0.88 = 31.1 lbs
Distributed Self Weight (ws) = = 6.83 plf
800 plf
300 plf
ws = 6.83 plf
4.55 ft.
4.30 ft.
4.80 ft.
2656.40 lbs
2656.40 lbs
9/17/2020 3
Fbx' = (900)(1.15)(1)(1)(1)(1.1)(0.8)(1) = 910.8 psi
fb = = 803.4 psi
 fb = 803.4 psi < Fbx' = 910.8 psi  (CSI = 0.88)   ➜  OK
9/17/2020 4
fv* = = 89.99 psi
 fv* = 89.99 psi < Fvx' = 160.63 psi  (CSI = 0.56)   ➜  OK
fv = = 136.11 psi
 fv = 136.11 psi < Fvx' = 160.63 psi  (CSI = 0.85)   ➜  OK
9/17/2020 5
ΔLL = = 0.03 in.
(L/d)LL = 54.60 / 0.03 = 1916
 ΔLL = 0.03 in = L/1916 < L/240   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 54.60 / 0.04 = 1385
 ΔTL = 0.04 in = L/1385 < L/180   ➜  OK
fc⊥ = = 295.2 psi
 fc⊥ = 295.2 psi < Fc⊥x' = 418.75 psi  (CSI = 0.70)   ➜  OK
9/17/2020 6
