Beam Design - Wilson
Size: 5.125 x 16.5
Design Span (L): 18.54 ft.
Clear Span: 18.08 ft.
Total Span: 19.00 ft.
Bearing (lb): 5.5 in.
Selfweight: 367.6 lbs
Dist. Selfweight: 19.83 plf
Total Weight: 376.7 lbs
CV Volume Factor 0.981b - - - - -
Beam Design Jeff Wilson 2020A190
9/12/2020 1
b = 5.125 in.
d = 16.500 in.
A = 5.125 x 16.500 = 84.56 in.2
Sx = (5.125)(16.500)2/6 = 232.55 in.3
Sy = (5.125)2(16.500)/6 = 72.23 in.3
Ix = (5.125)(16.500)3/12 = 1918.51 in.4
Iy = (5.125)3(16.500)/12 = 185.09 in.4
9/12/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [84.56 x (222.50 + 5.5)] x (12 in./ft.)3 = 11.16 ft3
Volumespan = N[A x L] = 1 x [84.56 x 222.50] x (12 in./ft.)3 = 10.89 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 11.16 = 376.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 10.89 = 367.6 lbs
Distributed Self Weight (ws) = = 19.83 plf
  ws = 19.83 plf
18.54 ft.
18.08 ft.
19.00 ft.
1850.88 lbs
1850.88 lbs
9/12/2020 3
CV = = 0.981
CV = 0.981 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.981) = 2707.0 psi
fb = = 432.1 psi
 fb = 432.1 psi < Fbx' = 2707.0 psi  (CSI = 0.16)   ➜  OK
9/12/2020 4
fv* = = 27.29 psi
 fv* = 27.29 psi < Fvx' = 304.75 psi  (CSI = 0.09)   ➜  OK
fv = = 32.04 psi
 fv = 32.04 psi < Fvx' = 304.75 psi  (CSI = 0.11)   ➜  OK
9/12/2020 5
ΔLL = = 0.08 in.
(L/d)LL = 222.50 / 0.08 = 2889
 ΔLL = 0.08 in = L/2889 < L/360   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 222.50 / 0.15 = 1483
 ΔTL = 0.15 in = L/1483 < L/240   ➜  OK
fc⊥ = = 65.7 psi
 fc⊥ = 65.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.10)   ➜  OK
9/12/2020 6
