Beam Design - Garage
Grade: SPF SS
Design Span (L): 21.75 ft.
Clear Span: 21.50 ft.
Total Span: 22.00 ft.
Live Load: 40 plf
Dead Load: 15 plf
Selfweight: 74.2 lbs
Dist. Selfweight: 3.41 plf
Total Weight: 75.0 lbs
Beam Design Dominic Fontana Null Garage
2/13/2020 1
2/13/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (261.00 + 3)] x (12 in./ft.)3 = 2.58 ft3
Volumespan = N[A x L] = 1 x [16.88 x 261.00] x (12 in./ft.)3 = 2.55 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 2.58 = 75.0 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.55 = 74.2 lbs
Distributed Self Weight (ws) = = 3.41 plf
40 plf
15 plf
ws = 3.41 plf
21.75 ft.
21.50 ft.
22.00 ft.
642.51 lbs
642.51 lbs
2/13/2020 3
Fbx' = (1250)(1.00)(1)(1)(1)(1)(1)(1.15) = 1437.5 psi
fb = = 1309.9 psi
 fb = 1309.9 psi < Fbx' = 1437.5 psi  (CSI = 0.91)   ➜  OK
2/13/2020 4
fv* = = 51.60 psi
 fv* = 51.60 psi < Fvx' = 135.00 psi  (CSI = 0.38)   ➜  OK
fv = = 56.46 psi
 fv = 56.46 psi < Fvx' = 135.00 psi  (CSI = 0.42)   ➜  OK
2/13/2020 5
ΔLL = = 0.75 in.
(L/d)LL = 261.00 / 0.75 = 346
 ΔLL = 0.75 in = L/346 > L/360   ➜  NG
ΔTL = = 1.10 in.
(L/d)TL = 261.00 / 1.10 = 237
 ΔTL = 1.10 in = L/237 > L/240   ➜  NG
fc⊥ = = 142.8 psi
 fc⊥ = 142.8 psi < Fc⊥x' = 425.00 psi  (CSI = 0.34)   ➜  OK
2/13/2020 6
