Beam Design - Stairs Floor Beam
Design Span (L): 5.25 ft.
Clear Span: 5.00 ft.
Total Span: 5.50 ft.
Live Load: 540 plf
Dead Load: 270 plf
Selfweight: 42.1 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 44.1 lbs
Beam Design Brent Jensen 2020A186
9/8/2020 1
9/8/2020 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (63.00 + 3)] x (12 in./ft.)3 = 1.29 ft3
Volumespan = N[A x L] = 2 x [16.88 x 63.00] x (12 in./ft.)3 = 1.23 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.29 = 44.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.23 = 42.1 lbs
540 plf
270 plf
ws = 8.02 plf
5.25 ft.
5.00 ft.
5.50 ft.
2249.55 lbs
2249.55 lbs
9/8/2020 3
fb = = 534.4 psi
 fb = 534.4 psi < Fbx' = 900.0 psi  (CSI = 0.59)   ➜  OK
9/8/2020 4
fv* = = 61.35 psi
 fv* = 61.35 psi < Fvx' = 180.00 psi  (CSI = 0.34)   ➜  OK
fv = = 95.44 psi
 fv = 95.44 psi < Fvx' = 180.00 psi  (CSI = 0.53)   ➜  OK
9/8/2020 5
ΔLL = = 0.02 in.
(L/d)LL = 63.00 / 0.02 = 3887
 ΔLL = 0.02 in = L/3887 < L/360   ➜  OK
ΔTL = = 0.02 in.
(L/d)TL = 63.00 / 0.02 = 2566
 ΔTL = 0.02 in = L/2566 < L/240   ➜  OK
fc⊥ = = 249.9 psi
 fc⊥ = 249.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.40)   ➜  OK
9/8/2020 6
