Beam Design - Front Porch Deck Beam
Species: Hem-Fir
Grade: HF No.2
Design Span (L): 8.25 ft.
Clear Span: 8.00 ft.
Total Span: 8.50 ft.
Live Load: 240 plf
Dead Load: 60 plf
Selfweight: 49.3 lbs
Dist. Selfweight: 5.97 plf
Total Weight: 50.8 lbs
Beam Design Brent Jensen 2020A185
9/8/2020 1
G = 0.43
9/8/2020 2
= 30.99 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (99.00 + 3)] x (12 in./ft.)3 = 1.64 ft3
Volumespan = N[A x L] = 2 x [13.88 x 99.00] x (12 in./ft.)3 = 1.59 ft3
Total Weight (WT) = ρw x Volumetotal = 30.99 x 1.64 = 50.8 lbs
Self Weight (WS) = ρw x Volumespan = 30.99 x 1.59 = 49.3 lbs
Distributed Self Weight (ws) = = 5.97 plf
240 plf
60 plf
ws = 5.97 plf
8.25 ft.
8.50 ft.
1300.38 lbs
1300.38 lbs
9/8/2020 3
Fbx' = (850)(1.15)(1)(1)(1)(1.1)(1)(1) = 1075.3 psi
fb = = 730.2 psi
 fb = 730.2 psi < Fbx' = 1075.3 psi  (CSI = 0.68)   ➜  OK
9/8/2020 4
fv* = = 55.47 psi
 fv* = 55.47 psi < Fvx' = 167.32 psi  (CSI = 0.33)   ➜  OK
fv = = 68.22 psi
 fv = 68.22 psi < Fvx' = 167.32 psi  (CSI = 0.41)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1300000(0.9)(1)(1) = 1170000 psi
9/8/2020 5
ΔLL = = 0.11 in.
(L/d)LL = 99.00 / 0.11 = 916
 ΔLL = 0.11 in = L/916 < L/360   ➜  OK
ΔTL = = 0.14 in.
(L/d)TL = 99.00 / 0.14 = 719
 ΔTL = 0.14 in = L/719 < L/240   ➜  OK
fc⊥ = = 144.5 psi
 fc⊥ = 144.5 psi < Fc⊥x' = 271.35 psi  (CSI = 0.53)   ➜  OK
9/8/2020 6
