Species: Hem-Fir
Grade: HF SS
Design Span (L): 8.25 ft.
Clear Span: 8.00 ft.
Total Span: 8.50 ft.
Live Load: 320 plf
Dead Load: 80 plf
Selfweight: 49.3 lbs
Dist. Selfweight: 5.97 plf
Total Weight: 50.8 lbs
Beam Design 2020A182
9/8/2020 1
G = 0.43
9/8/2020 2
= 30.99 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (99.00 + 3)] x (12 in./ft.)3 = 1.64 ft3
Volumespan = N[A x L] = 2 x [13.88 x 99.00] x (12 in./ft.)3 = 1.59 ft3
Total Weight (WT) = ρw x Volumetotal = 30.99 x 1.64 = 50.8 lbs
Self Weight (WS) = ρw x Volumespan = 30.99 x 1.59 = 49.3 lbs
Distributed Self Weight (ws) = = 5.97 plf
320 plf
80 plf
ws = 5.97 plf
8.25 ft.
8.50 ft.
1725.38 lbs
1725.38 lbs
9/8/2020 3
Fbx' = (1400)(1.15)(0.85)(1)(1)(1.1)(1)(1) = 1505.3 psi
fb = = 968.8 psi
 fb = 968.8 psi < Fbx' = 1505.3 psi  (CSI = 0.64)   ➜  OK
9/8/2020 4
fv* = = 73.61 psi
 fv* = 73.61 psi < Fvx' = 167.32 psi  (CSI = 0.44)   ➜  OK
fv = = 90.52 psi
 fv = 90.52 psi < Fvx' = 167.32 psi  (CSI = 0.54)   ➜  OK
9/8/2020 5
ΔLL = = 0.12 in.
(L/d)LL = 99.00 / 0.12 = 846
 ΔLL = 0.12 in = L/846 < L/360   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 99.00 / 0.15 = 667
 ΔTL = 0.15 in = L/667 < L/240   ➜  OK
fc⊥ = = 191.7 psi
 fc⊥ = 191.7 psi < Fc⊥x' = 271.35 psi  (CSI = 0.71)   ➜  OK
9/8/2020 6
