Design Span (L): 6.35 ft.
Clear Span: 6.10 ft.
Total Span: 6.60 ft.
Live Load: 600 plf
Dead Load: 400 plf
Selfweight: 55.6 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 57.7 lbs
Load Duration: 1.33
Beam Design 11055 Greenwood Road 2020A178
9/5/2020 1
9/5/2020 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (76.20 + 3)] x (12 in./ft.)3 = 1.55 ft3
Volumespan = N[A x L] = 2 x [16.88 x 76.20] x (12 in./ft.)3 = 1.49 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.55 = 57.7 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.49 = 55.6 lbs
600 plf
400 plf
ws = 8.75 plf
6.35 ft.
6.10 ft.
6.60 ft.
3328.87 lbs
3328.87 lbs
9/5/2020 3
Fbx' = (750)(1.33)(1)(1)(1)(1)(1)(1) = 997.5 psi
fb = = 964.2 psi
 fb = 964.2 psi < Fbx' = 997.5 psi  (CSI = 0.97)   ➜  OK
9/5/2020 4
Fvx' = (175)(1.33)(1)(1)(1) = 232.75 psi
fv* = = 100.31 psi
 fv* = 100.31 psi < Fvx' = 232.75 psi  (CSI = 0.43)   ➜  OK
fv = = 142.35 psi
 fv = 142.35 psi < Fvx' = 232.75 psi  (CSI = 0.61)   ➜  OK
9/5/2020 5
ΔLL = = 0.04 in.
(L/d)LL = 76.20 / 0.04 = 1730
 ΔLL = 0.04 in = L/1730 < L/360   ➜  OK
ΔTL = = 0.07 in.
(L/d)TL = 76.20 / 0.07 = 1029
 ΔTL = 0.07 in = L/1029 < L/240   ➜  OK
fc⊥ = = 369.9 psi
 fc⊥ = 369.9 psi < Fc⊥x' = 565.00 psi  (CSI = 0.65)   ➜  OK
9/5/2020 6
