Beam Design - Beam Calc
Size: 3.5 x 13.5
Design Span (L): 29.75 ft.
Clear Span: 29.50 ft.
Total Span: 30.00 ft.
Selfweight: 329.6 lbs
Dist. Selfweight: 11.08 plf
Total Weight: 332.3 lbs
CV Volume Factor 0.992b - - - - -
Beam Design David Heumann 2330 Vehicle Drive, 20-006
9/3/2020 1
d = 13.500 in.
A = 3.500 x 13.500 = 47.25 in.2
Sx = (3.500)(13.500)2/6 = 106.31 in.3
Sy = (3.500)2(13.500)/6 = 27.56 in.3
Ix = (3.500)(13.500)3/12 = 717.61 in.4
Iy = (3.500)3(13.500)/12 = 48.23 in.4
9/3/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [47.25 x (357.00 + 3)] x (12 in./ft.)3 = 9.84 ft3
Volumespan = N[A x L] = 1 x [47.25 x 357.00] x (12 in./ft.)3 = 9.76 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 9.84 = 332.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 9.76 = 329.6 lbs
Distributed Self Weight (ws) = = 11.08 plf
  ws = 11.08 plf
29.75 ft.
29.50 ft.
30.00 ft.
2791.17 lbs
2791.17 lbs
9/3/2020 3
CV = = 0.992
CV = 0.992 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.992) = 2736.7 psi
fb = = 2323.7 psi
 fb = 2323.7 psi < Fbx' = 2736.7 psi  (CSI = 0.85)   ➜  OK
9/3/2020 4
fv* = = 81.22 psi
 fv* = 81.22 psi < Fvx' = 304.75 psi  (CSI = 0.27)   ➜  OK
fv = = 87.87 psi
 fv = 87.87 psi < Fvx' = 304.75 psi  (CSI = 0.29)   ➜  OK
9/3/2020 5
ΔLL = = 1.36 in.
(L/d)LL = 357.00 / 1.36 = 262
 ΔLL = 1.36 in = L/262 > L/360   ➜  NG
ΔTL = = 2.54 in.
(L/d)TL = 357.00 / 2.54 = 141
 ΔTL = 2.54 in = L/141 > L/240   ➜  NG
fc⊥ = = 265.8 psi
 fc⊥ = 265.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.41)   ➜  OK
9/3/2020 6
