Size: 2.5 x 6
Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Selfweight: 69.5 lbs
Dist. Selfweight: 3.52 plf
Total Weight: 70.3 lbs
Beam Design 2020A175
8/19/2020 1
b = 2.500 in.
d = 6.000 in.
A = 2.500 x 6.000 = 15.00 in.2
Sx = (2.500)(6.000)2/6 = 15.00 in.3
Sy = (2.500)2(6.000)/6 = 6.25 in.3
Ix = (2.500)(6.000)3/12 = 45.00 in.4
Iy = (2.500)3(6.000)/12 = 7.81 in.4
8/19/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [15.00 x (237.00 + 3)] x (12 in./ft.)3 = 2.08 ft3
Volumespan = N[A x L] = 1 x [15.00 x 237.00] x (12 in./ft.)3 = 2.06 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 2.08 = 70.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 2.06 = 69.5 lbs
  ws = 3.52 plf
19.75 ft.
19.50 ft.
1785.17 lbs
1785.17 lbs
8/19/2020 3
fb = = 6963.3 psi
 fb = 6963.3 psi > Fbx' = 2760.0 psi  (CSI = 2.52)   ➜  NG
8/19/2020 4
fv* = = 167.36 psi
 fv* = 167.36 psi < Fvx' = 304.75 psi  (CSI = 0.55)   ➜  OK
fv = = 176.29 psi
 fv = 176.29 psi < Fvx' = 304.75 psi  (CSI = 0.58)   ➜  OK
8/19/2020 5
ΔLL = = 4.23 in.
(L/d)LL = 237.00 / 4.23 = 56
 ΔLL = 4.23 in = L/56 > L/360   ➜  NG
ΔTL = = 7.54 in.
(L/d)TL = 237.00 / 7.54 = 31
 ΔTL = 7.54 in = L/31 > L/240   ➜  NG
fc⊥ = = 238.0 psi
 fc⊥ = 238.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.37)   ➜  OK
8/19/2020 6
