Beam Design - Beam2
Grade: SP DSS
Live Load: 70 plf
Dead Load: 11.1 plf
Selfweight: 42.3 lbs
Dist. Selfweight: 3.60 plf
Total Weight: 43.2 lbs
Beam Design Dominic Fontana Kahn2
1/29/2020 1
1/29/2020 2
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.16 = 43.2 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.13 = 42.3 lbs
70 plf
11.1 plf
ws = 3.60 plf
508.18 lbs
508.18 lbs
1/29/2020 3
Fbx' = (1950)(1.15)(1)(1)(1)(1)(1)(1) = 2242.5 psi
fb = = 820.0 psi
 fb = 820.0 psi < Fbx' = 2242.5 psi  (CSI = 0.37)   ➜  OK
1/29/2020 4
fv* = = 46.74 psi
 fv* = 46.74 psi < Fvx' = 201.25 psi  (CSI = 0.23)   ➜  OK
fv = = 53.79 psi
 fv = 53.79 psi < Fvx' = 201.25 psi  (CSI = 0.27)   ➜  OK
1/29/2020 5
ΔLL = = 0.16 in.
(L/d)LL = 141.00 / 0.16 = 883
 ΔLL = 0.16 in = L/883 < L/360   ➜  OK
ΔTL = = 0.19 in.
(L/d)TL = 141.00 / 0.19 = 730
 ΔTL = 0.19 in = L/730 < L/240   ➜  OK
fc⊥ = = 112.9 psi
 fc⊥ = 112.9 psi < Fc⊥x' = 660.00 psi  (CSI = 0.17)   ➜  OK
1/29/2020 6
