Grade: SPF SS
Design Span (L): 12.83 ft.
Clear Span: 12.67 ft.
Total Span: 13.00 ft.
Bearing (lb): 2 in.
Live Load: 40 plf
Dead Load: 10 plf
Selfweight: 21.4 lbs
Dist. Selfweight: 1.67 plf
Total Weight: 21.7 lbs
Load Duration: 1.25
Beam Design 2020A168
8/7/2020 1
8/7/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (154.00 + 2)] x (12 in./ft.)3 = 0.74 ft3
Volumespan = N[A x L] = 1 x [8.25 x 154.00] x (12 in./ft.)3 = 0.74 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.74 = 21.7 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.74 = 21.4 lbs
40 plf
10 plf
ws = 1.67 plf
12.83 ft.
12.67 ft.
13.00 ft.
335.83 lbs
335.83 lbs
8/7/2020 3
Fbx' = (1250)(1.25)(1)(1)(1)(1.3)(1)(1) = 2031.3 psi
fb = = 1687.7 psi
 fb = 1687.7 psi < Fbx' = 2031.3 psi  (CSI = 0.83)   ➜  OK
8/7/2020 4
Fvx' = (135)(1.25)(1)(1)(1) = 168.75 psi
fv* = = 55.97 psi
 fv* = 55.97 psi < Fvx' = 168.75 psi  (CSI = 0.33)   ➜  OK
fv = = 60.28 psi
 fv = 60.28 psi < Fvx' = 168.75 psi  (CSI = 0.36)   ➜  OK
8/7/2020 5
ΔLL = = 0.78 in.
(L/d)LL = 154.00 / 0.78 = 197
 ΔLL = 0.78 in = L/197 < L/180   ➜  OK
ΔTL = = 1.01 in.
(L/d)TL = 154.00 / 1.01 = 152
 ΔTL = 1.01 in = L/152 < L/120   ➜  OK
fc⊥ = = 111.9 psi
 fc⊥ = 111.9 psi < Fc⊥x' = 425.00 psi  (CSI = 0.26)   ➜  OK
8/7/2020 6
