Beam Design - 4x8x16 Pavilion Beam
Species: Western Cedars
Grade: WC No.1
Size: 4 x 8
Design Span (L): 15.83 ft.
Clear Span: 15.67 ft.
Total Span: 16.00 ft.
Bearing (lb): 2 in.
Live Load: 10 plf
Dead Load: 35 plf
Selfweight: 70.3 lbs
Dist. Selfweight: 4.44 plf
Total Weight: 71.0 lbs
Beam Design scott mangrum 123 Robbie Drive, Byron GA 2020A167
8/6/2020 1
WC No.1 725 425 155 425 825 1000000 370000 0.36
G = 0.36
8/6/2020 2
= 25.18 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (190.00 + 2)] x (12 in./ft.)3 = 2.82 ft3
Volumespan = N[A x L] = 1 x [25.38 x 190.00] x (12 in./ft.)3 = 2.79 ft3
Total Weight (WT) = ρw x Volumetotal = 25.18 x 2.82 = 71.0 lbs
Self Weight (WS) = ρw x Volumespan = 25.18 x 2.79 = 70.3 lbs
Distributed Self Weight (ws) = = 4.44 plf
10 plf
35 plf
ws = 4.44 plf
15.83 ft.
15.67 ft.
395.49 lbs
395.49 lbs
8/6/2020 3
Fbx' = (725)(1.00)(1)(1)(1)(1.3)(1)(1) = 942.5 psi
fb = = 606.3 psi
 fb = 606.3 psi < Fbx' = 942.5 psi  (CSI = 0.64)   ➜  OK
8/6/2020 4
Fvx' = (155)(1.00)(1)(1)(1) = 155.00 psi
fv* = = 21.37 psi
 fv* = 21.37 psi < Fvx' = 155.00 psi  (CSI = 0.14)   ➜  OK
fv = = 23.14 psi
 fv = 23.14 psi < Fvx' = 155.00 psi  (CSI = 0.15)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1000000(1)(1)(1) = 1000000 psi
8/6/2020 5
ΔLL = = 0.13 in.
(L/d)LL = 190.00 / 0.13 = 1494
 ΔLL = 0.13 in = L/1494 < L/180   ➜  OK
ΔTL = = 0.63 in.
(L/d)TL = 190.00 / 0.63 = 302
 ΔTL = 0.63 in = L/302 < L/120   ➜  OK
Ab = b x lb = 3.5 x 2 = 7.00 in2
fc⊥ = = 56.5 psi
 fc⊥ = 56.5 psi < Fc⊥x' = 425.00 psi  (CSI = 0.13)   ➜  OK
8/6/2020 6
