Species: Western Cedars
Grade: WC No.1
Size: 4 x 6
Design Span (L): 15.83 ft.
Clear Span: 15.67 ft.
Total Span: 16.00 ft.
Bearing (lb): 2 in.
Live Load: 10 plf
Dead Load: 35 plf
Selfweight: 53.3 lbs
Dist. Selfweight: 3.37 plf
Total Weight: 53.9 lbs
Beam Design 2020A164
8/6/2020 1
WC No.1 725 425 155 425 825 1000000 370000 0.36
G = 0.36
8/6/2020 2
= 25.18 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (190.00 + 2)] x (12 in./ft.)3 = 2.14 ft3
Volumespan = N[A x L] = 1 x [19.25 x 190.00] x (12 in./ft.)3 = 2.12 ft3
Total Weight (WT) = ρw x Volumetotal = 25.18 x 2.14 = 53.9 lbs
Self Weight (WS) = ρw x Volumespan = 25.18 x 2.12 = 53.3 lbs
Distributed Self Weight (ws) = = 3.37 plf
10 plf
35 plf
ws = 3.37 plf
15.83 ft.
15.67 ft.
386.92 lbs
386.92 lbs
8/6/2020 3
Fbx' = (725)(1.00)(1)(1)(1)(1.3)(1)(1) = 942.5 psi
fb = = 1030.7 psi
 fb = 1030.7 psi > Fbx' = 942.5 psi  (CSI = 1.09)   ➜  NG
8/6/2020 4
Fvx' = (155)(1.00)(1)(1)(1) = 155.00 psi
fv* = = 28.11 psi
 fv* = 28.11 psi < Fvx' = 155.00 psi  (CSI = 0.18)   ➜  OK
fv = = 29.84 psi
 fv = 29.84 psi < Fvx' = 155.00 psi  (CSI = 0.19)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1000000(1)(1)(1) = 1000000 psi
8/6/2020 5
ΔLL = = 0.29 in.
(L/d)LL = 190.00 / 0.29 = 652
 ΔLL = 0.29 in = L/652 < L/180   ➜  OK
ΔTL = = 1.41 in.
(L/d)TL = 190.00 / 1.41 = 135
 ΔTL = 1.41 in = L/135 < L/120   ➜  OK
Ab = b x lb = 3.5 x 2 = 7.00 in2
fc⊥ = = 55.3 psi
 fc⊥ = 55.3 psi < Fc⊥x' = 425.00 psi  (CSI = 0.13)   ➜  OK
8/6/2020 6
