Species: Hem-Fir
Grade: HF No.2
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 60 plf
Dead Load: 15 plf
Selfweight: 135.4 lbs
Dist. Selfweight: 8.60 plf
Total Weight: 137.6 lbs
Beam Design 2020A161
7/30/2020 1
G = 0.43
7/30/2020 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (189.00 + 3)] x (12 in./ft.)3 = 4.63 ft3
Volumespan = N[A x L] = 3 x [13.88 x 189.00] x (12 in./ft.)3 = 4.55 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 4.63 = 137.6 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 4.55 = 135.4 lbs
Distributed Self Weight (ws) = = 8.60 plf
60 plf
15 plf
ws = 8.60 plf
15.75 ft.
15.50 ft.
668.78 lbs
668.78 lbs
7/30/2020 3
Fbx' = (850)(1.15)(1)(1)(1)(1.1)(1)(1) = 1075.3 psi
fb = = 484.7 psi
 fb = 484.7 psi < Fbx' = 1075.3 psi  (CSI = 0.45)   ➜  OK
7/30/2020 4
Fvx' = (150)(1.15)(1)(1)(1) = 172.50 psi
fv* = = 21.40 psi
 fv* = 21.40 psi < Fvx' = 172.50 psi  (CSI = 0.12)   ➜  OK
fv = = 23.72 psi
 fv = 23.72 psi < Fvx' = 172.50 psi  (CSI = 0.14)   ➜  OK
7/30/2020 5
ΔLL = = 0.22 in.
(L/d)LL = 189.00 / 0.22 = 878
 ΔLL = 0.22 in = L/878 < L/180   ➜  OK
ΔTL = = 0.30 in.
(L/d)TL = 189.00 / 0.30 = 630
 ΔTL = 0.30 in = L/630 < L/120   ➜  OK
fc⊥ = = 49.5 psi
 fc⊥ = 49.5 psi < Fc⊥x' = 405.00 psi  (CSI = 0.12)   ➜  OK
7/30/2020 6
