Grade: 24F-V3 1.8E SP/SP
Size: 2.5 x 9.625
Design Span (L): 12.00 ft.
Clear Span: 11.75 ft.
Total Span: 12.25 ft.
Live Load: 410 plf
Dead Load: 140 plf
Selfweight: 147.9 lbs
Dist. Selfweight: 12.33 plf
Total Weight: 151.0 lbs
Beam Design 2020A158
7/11/2020 1
b = 2.500 in.
d = 9.625 in.
A = 2.500 x 9.625 = 24.06 in.2
Sx = (2.500)(9.625)2/6 = 38.60 in.3
Sy = (2.500)2(9.625)/6 = 10.03 in.3
Ix = (2.500)(9.625)3/12 = 185.76 in.4
Iy = (2.500)3(9.625)/12 = 12.53 in.4
7/11/2020 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [24.06 x (144.00 + 3)] x (12 in./ft.)3 = 4.09 ft3
Volumespan = N[A x L] = 2 x [24.06 x 144.00] x (12 in./ft.)3 = 4.01 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 4.09 = 151.0 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 4.01 = 147.9 lbs
Distributed Self Weight (ws) = = 12.33 plf
410 plf
140 plf
  ws = 12.33 plf
12.25 ft.
3444.26 lbs
3444.26 lbs
7/11/2020 3
fb = = 1573.3 psi
 fb = 1573.3 psi < Fbx' = 2760.0 psi  (CSI = 0.57)   ➜  OK
7/11/2020 4
fv* = = 91.10 psi
 fv* = 91.10 psi < Fvx' = 345.00 psi  (CSI = 0.26)   ➜  OK
fv = = 105.16 psi
 fv = 105.16 psi < Fvx' = 345.00 psi  (CSI = 0.30)   ➜  OK
7/11/2020 5
ΔLL = = 0.29 in.
(L/d)LL = 144.00 / 0.29 = 503
 ΔLL = 0.29 in = L/503 < L/360   ➜  OK
ΔTL = = 0.39 in.
(L/d)TL = 144.00 / 0.39 = 367
 ΔTL = 0.39 in = L/367 < L/240   ➜  OK
fc⊥ = = 229.6 psi
 fc⊥ = 229.6 psi < Fc⊥x' = 740.00 psi  (CSI = 0.31)   ➜  OK
7/11/2020 6
