Grade: SPF No.2
Size: 2 x 4
Design Span (L): 4.00 ft.
Clear Span: 3.88 ft.
Total Span: 4.13 ft.
Bearing (lb): 1.5 in.
Live Load: 70 plf
Dead Load: 15 plf
Selfweight: 4.2 lbs
Dist. Selfweight: 1.06 plf
Total Weight: 4.4 lbs
Orientation: Horizontal
Beam Design 2020A155
7/10/2020 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
7/10/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [5.25 x (48.00 + 1.5)] x (12 in./ft.)3 = 0.15 ft3
Volumespan = N[A x L] = 1 x [5.25 x 48.00] x (12 in./ft.)3 = 0.15 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.15 = 4.4 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.15 = 4.2 lbs
Distributed Self Weight (ws) = = 1.06 plf
70 plf
15 plf
ws = 1.06 plf
4.00 ft.
3.88 ft.
4.13 ft.
177.50 lbs
177.50 lbs
7/10/2020 3
Fby' = (875)(1.15)(1)(1)(1)(1.5)(1.1)(1)(1.15) = 1909.4 psi
fb = = 1573.7 psi
 fb = 1573.7 psi < Fby' = 1909.4 psi  (CSI = 0.82)   ➜  OK
7/10/2020 4
Fvy' = (135)(1.15)(1)(1)(1) = 155.25 psi
fv* = = 46.10 psi
 fv* = 46.10 psi < Fvy' = 155.25 psi  (CSI = 0.30)   ➜  OK
fv = = 49.18 psi
 fv = 49.18 psi < Fvy' = 155.25 psi  (CSI = 0.32)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1400000(1)(1)(1) = 1400000 psi
7/10/2020 5
ΔLL = = 0.29 in.
(L/d)LL = 48.00 / 0.29 = 164
 ΔLL = 0.29 in = L/164 > L/180   ➜  NG
ΔTL = = 0.36 in.
(L/d)TL = 48.00 / 0.36 = 133
 ΔTL = 0.36 in = L/133 < L/120   ➜  OK
Fc⊥y' = (425)(1)(1)(1) = 425.00 psi
Ab = d x lb = 3.5 x 1.5 = 5.25 in2
fc⊥ = = 33.8 psi
 fc⊥ = 33.8 psi < Fc⊥y' = 425.00 psi  (CSI = 0.08)   ➜  OK
7/10/2020 6
