Beam Design - Beam
Grade: SP DSS
Design Span (L): 14.75 ft.
Clear Span: 14.50 ft.
Total Span: 15.00 ft.
Live Load: 70 plf
Dead Load: 11 plf
Selfweight: 53.1 lbs
Dist. Selfweight: 3.60 plf
Total Weight: 54.0 lbs
Beam Design Dominic Fontana Kahn1
1/29/2020 1
1/29/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (177.00 + 3)] x (12 in./ft.)3 = 1.45 ft3
Volumespan = N[A x L] = 1 x [13.88 x 177.00] x (12 in./ft.)3 = 1.42 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.45 = 54.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.42 = 53.1 lbs
70 plf
11 plf
ws = 3.60 plf
14.75 ft.
14.50 ft.
15.00 ft.
634.48 lbs
634.48 lbs
1/29/2020 3
Fbx' = (1950)(1.15)(1)(1)(1)(1)(1)(1) = 2242.5 psi
fb = = 1290.6 psi
 fb = 1290.6 psi < Fbx' = 2242.5 psi  (CSI = 0.58)   ➜  OK
1/29/2020 4
fv* = = 60.40 psi
 fv* = 60.40 psi < Fvx' = 201.25 psi  (CSI = 0.30)   ➜  OK
fv = = 67.45 psi
 fv = 67.45 psi < Fvx' = 201.25 psi  (CSI = 0.34)   ➜  OK
1/29/2020 5
ΔLL = = 0.40 in.
(L/d)LL = 177.00 / 0.40 = 446
 ΔLL = 0.40 in = L/446 < L/360   ➜  OK
ΔTL = = 0.48 in.
(L/d)TL = 177.00 / 0.48 = 369
 ΔTL = 0.48 in = L/369 < L/240   ➜  OK
fc⊥ = = 141.0 psi
 fc⊥ = 141.0 psi < Fc⊥x' = 660.00 psi  (CSI = 0.21)   ➜  OK
1/29/2020 6
