Size: 5.5 x 7.5
Design Span (L): 8.25 ft.
Clear Span: 8.00 ft.
Total Span: 8.50 ft.
Live Load: 949 plf
Dead Load: 410 plf
Selfweight: 79.8 lbs
Dist. Selfweight: 9.67 plf
Total Weight: 82.2 lbs
Beam Design 2020A149
6/28/2020 1
d = 7.500 in.
A = 5.500 x 7.500 = 41.25 in.2
Sx = (5.500)(7.500)2/6 = 51.56 in.3
Sy = (5.500)2(7.500)/6 = 37.81 in.3
Ix = (5.500)(7.500)3/12 = 193.36 in.4
Iy = (5.500)3(7.500)/12 = 103.98 in.4
6/28/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [41.25 x (99.00 + 3)] x (12 in./ft.)3 = 2.43 ft3
Volumespan = N[A x L] = 1 x [41.25 x 99.00] x (12 in./ft.)3 = 2.36 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 2.43 = 82.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 2.36 = 79.8 lbs
Distributed Self Weight (ws) = = 9.67 plf
949 plf
410 plf
  ws = 9.67 plf
8.25 ft.
8.50 ft.
5816.85 lbs
5816.85 lbs
6/28/2020 3
fb = = 2710.0 psi
 fb = 2710.0 psi < Fbx' = 2760.0 psi  (CSI = 0.98)   ➜  OK
6/28/2020 4
fv* = = 174.19 psi
 fv* = 174.19 psi < Fvx' = 304.75 psi  (CSI = 0.57)   ➜  OK
fv = = 205.30 psi
 fv = 205.30 psi < Fvx' = 304.75 psi  (CSI = 0.67)   ➜  OK
6/28/2020 5
ΔLL = = 0.28 in.
(L/d)LL = 99.00 / 0.28 = 348
 ΔLL = 0.28 in = L/348 < L/240   ➜  OK
ΔTL = = 0.41 in.
(L/d)TL = 99.00 / 0.41 = 242
 ΔTL = 0.41 in = L/242 < L/180   ➜  OK
fc⊥ = = 352.5 psi
 fc⊥ = 352.5 psi < Fc⊥x' = 650.00 psi  (CSI = 0.54)   ➜  OK
6/28/2020 6
