Size: 5.5 x 13.5
Design Span (L): 24.75 ft.
Clear Span: 24.50 ft.
Total Span: 25.00 ft.
Selfweight: 452.6 lbs
Dist. Selfweight: 18.29 plf
Total Weight: 457.2 lbs
Load Duration: 1.33
CV Volume Factor 0.965b - - - - -
Beam Design 2020A144
6/18/2020 1
d = 13.500 in.
6/18/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [74.25 x (297.00 + 3)] x (12 in./ft.)3 = 12.89 ft3
Volumespan = N[A x L] = 1 x [74.25 x 297.00] x (12 in./ft.)3 = 12.76 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 12.89 = 457.2 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 12.76 = 452.6 lbs
Distributed Self Weight (ws) = = 18.29 plf
  ws = 18.29 plf
24.75 ft.
24.50 ft.
25.00 ft.
2416.10 lbs
2416.10 lbs
6/18/2020 3
CV = = 0.965
CV = 0.965 < CL = 1
Fbx' = (2400)(1.33)(0.8)(1)(0.965) = 2465.1 psi
fb = = 1063.1 psi
 fb = 1063.1 psi < Fbx' = 2465.1 psi  (CSI = 0.43)   ➜  OK
6/18/2020 4
Fvx' = (265)(1.33)(0.875)(1) = 308.39 psi
fv* = = 43.93 psi
 fv* = 43.93 psi < Fvx' = 308.39 psi  (CSI = 0.14)   ➜  OK
fv = = 48.32 psi
 fv = 48.32 psi < Fvx' = 308.39 psi  (CSI = 0.16)   ➜  OK
6/18/2020 5
ΔLL = = 0.50 in.
(L/d)LL = 297.00 / 0.50 = 595
 ΔLL = 0.50 in = L/595 < L/360   ➜  OK
ΔTL = = 0.97 in.
(L/d)TL = 297.00 / 0.97 = 308
 ΔTL = 0.97 in = L/308 < L/240   ➜  OK
fc⊥ = = 146.4 psi
 fc⊥ = 146.4 psi < Fc⊥x' = 344.50 psi  (CSI = 0.43)   ➜  OK
6/18/2020 6
