Grade: SPF SS
Design Span (L): 11.67 ft.
Clear Span: 11.33 ft.
Bearing (lb): 4 in.
Live Load: 280 plf
Dead Load: 210 plf
Selfweight: 76.9 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 79.1 lbs
Beam Design 2020A142
6/17/2020 1
6/17/2020 2
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (140.00 + 4)] x (12 in./ft.)3 = 2.72 ft3
Volumespan = N[A x L] = 3 x [10.88 x 140.00] x (12 in./ft.)3 = 2.64 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 2.72 = 79.1 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.64 = 76.9 lbs
280 plf
210 plf
ws = 6.59 plf
11.67 ft.
11.33 ft.
2979.64 lbs
2979.64 lbs
6/17/2020 3
Fbx' = (1250)(1.00)(1)(1)(1)(1.2)(1)(1) = 1500.0 psi
fb = = 2572.0 psi
 fb = 2572.0 psi > Fbx' = 1500.0 psi  (CSI = 1.71)   ➜  NG
6/17/2020 4
fv* = = 119.40 psi
 fv* = 119.40 psi < Fvx' = 135.00 psi  (CSI = 0.88)   ➜  OK
fv = = 133.19 psi
 fv = 133.19 psi < Fvx' = 135.00 psi  (CSI = 0.99)   ➜  OK
6/17/2020 5
ΔLL = = 0.54 in.
(L/d)LL = 140.00 / 0.54 = 257
 ΔLL = 0.54 in = L/257 > L/360   ➜  NG
ΔTL = = 0.97 in.
(L/d)TL = 140.00 / 0.97 = 145
 ΔTL = 0.97 in = L/145 > L/240   ➜  NG
fc⊥ = = 165.5 psi
 fc⊥ = 165.5 psi < Fc⊥x' = 425.00 psi  (CSI = 0.39)   ➜  OK
6/17/2020 6
