Design Span (L): 9.25 ft.
Clear Span: 9.00 ft.
Total Span: 9.50 ft.
Live Load: 514 plf
Dead Load: 129 plf
Selfweight: 115.3 lbs
Dist. Selfweight: 12.47 plf
Total Weight: 118.5 lbs
Beam Design 2020A139
6/15/2020 1
6/15/2020 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (111.00 + 3)] x (12 in./ft.)3 = 3.34 ft3
Volumespan = N[A x L] = 3 x [16.88 x 111.00] x (12 in./ft.)3 = 3.25 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 3.34 = 118.5 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 3.25 = 115.3 lbs
514 plf
129 plf
ws = 12.47 plf
9.25 ft.
9.00 ft.
9.50 ft.
3113.48 lbs
3113.48 lbs
6/15/2020 3
fb = = 886.3 psi
 fb = 886.3 psi < Fbx' = 1035.0 psi  (CSI = 0.86)   ➜  OK
6/15/2020 4
fv* = = 71.62 psi
 fv* = 71.62 psi < Fvx' = 200.79 psi  (CSI = 0.36)   ➜  OK
fv = = 89.82 psi
 fv = 89.82 psi < Fvx' = 200.79 psi  (CSI = 0.45)   ➜  OK
6/15/2020 5
ΔLL = = 0.11 in.
(L/d)LL = 111.00 / 0.11 = 1008
 ΔLL = 0.11 in = L/1008 < L/360   ➜  OK
ΔTL = = 0.14 in.
(L/d)TL = 111.00 / 0.14 = 790
 ΔTL = 0.14 in = L/790 < L/240   ➜  OK
fc⊥ = = 230.6 psi
 fc⊥ = 230.6 psi < Fc⊥x' = 418.75 psi  (CSI = 0.55)   ➜  OK
6/15/2020 6
