Design Span (L): 9.35 ft.
Clear Span: 9.10 ft.
Total Span: 9.60 ft.
Live Load: 229.16 plf
Dead Load: 57.29 plf
Selfweight: 77.7 lbs
Dist. Selfweight: 8.31 plf
Total Weight: 79.8 lbs
Beam Design 2020A137
6/15/2020 1
6/15/2020 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (112.20 + 3)] x (12 in./ft.)3 = 2.25 ft3
Volumespan = N[A x L] = 2 x [16.88 x 112.20] x (12 in./ft.)3 = 2.19 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 2.25 = 79.8 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 2.19 = 77.7 lbs
Distributed Self Weight (ws) = = 8.31 plf
229.16 plf
57.29 plf
ws = 8.31 plf
9.35 ft.
9.10 ft.
9.60 ft.
1414.86 lbs
1414.86 lbs
6/15/2020 3
fb = = 610.8 psi
 fb = 610.8 psi < Fbx' = 1035.0 psi  (CSI = 0.59)   ➜  OK
6/15/2020 4
fv* = = 48.96 psi
 fv* = 48.96 psi < Fvx' = 200.79 psi  (CSI = 0.24)   ➜  OK
fv = = 61.25 psi
 fv = 61.25 psi < Fvx' = 200.79 psi  (CSI = 0.31)   ➜  OK
6/15/2020 5
ΔLL = = 0.08 in.
(L/d)LL = 112.20 / 0.08 = 1459
 ΔLL = 0.08 in = L/1459 < L/360   ➜  OK
ΔTL = = 0.10 in.
(L/d)TL = 112.20 / 0.10 = 1135
 ΔTL = 0.10 in = L/1135 < L/240   ➜  OK
fc⊥ = = 157.2 psi
 fc⊥ = 157.2 psi < Fc⊥x' = 418.75 psi  (CSI = 0.38)   ➜  OK
6/15/2020 6
