Size: 4 x 14
Design Span (L): 17.54 ft.
Clear Span: 17.08 ft.
Total Span: 18.00 ft.
Bearing (lb): 5.5 in.
Live Load: 80 plf
Dead Load: 80 plf
Selfweight: 193.2 lbs
Dist. Selfweight: 11.02 plf
Total Weight: 198.3 lbs
Lateral Support: 16' o/c
CL Beam Stability Factor 0.957 - - - - -
Beam Design 2020A135
6/14/2020 1
d = 13.250 in.
6/14/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [46.38 x (210.50 + 5.5)] x (12 in./ft.)3 = 5.80 ft3
Volumespan = N[A x L] = 1 x [46.38 x 210.50] x (12 in./ft.)3 = 5.65 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 5.80 = 198.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 5.65 = 193.2 lbs
Distributed Self Weight (ws) = = 11.02 plf
80 plf
80 plf
ws = 11.02 plf
17.54 ft.
17.08 ft.
18.00 ft.
1539.17 lbs
1539.17 lbs
6/14/2020 3
lu = Unbraced Length = 16 ft.
lu/d = = 14.49
le = 1.84lu = 1.84(192.0) = 353.28 in. = 29.44 ft.  (NDS Table 3.3.3)
Rb = = 19.55
 Rb = 19.55 < 50   ➜  OK
6/14/2020 4
FbE = = 1821.42 psi
CL =   = 0.957
Fbx' = (900)(1.00)(1)(1)(0.957)(1)(1)(1) = 861.4 psi
fb = = 770.8 psi
 fb = 770.8 psi < Fbx' = 861.4 psi  (CSI = 0.89)   ➜  OK
fv* = = 42.41 psi
 fv* = 42.41 psi < Fvx' = 180.00 psi  (CSI = 0.24)   ➜  OK
fv = = 48.52 psi
 fv = 48.52 psi < Fvx' = 180.00 psi  (CSI = 0.27)   ➜  OK
6/14/2020 5
ΔLL = = 0.16 in.
(L/d)LL = 210.50 / 0.16 = 1341
 ΔLL = 0.16 in = L/1341 < L/360   ➜  OK
ΔTL = = 0.34 in.
(L/d)TL = 210.50 / 0.34 = 627
 ΔTL = 0.34 in = L/627 < L/240   ➜  OK
Ab = b x lb = 3.5 x 5.5 = 19.25 in2
fc⊥ = = 80.0 psi
 fc⊥ = 80.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.13)   ➜  OK
6/14/2020 6
