Size: 4 x 14
Design Span (L): 18.00 ft.
Clear Span: 17.75 ft.
Total Span: 18.25 ft.
Live Load: 80 plf
Dead Load: 80 plf
Selfweight: 198.3 lbs
Dist. Selfweight: 11.02 plf
Total Weight: 201.0 lbs
CL Beam Stability Factor 0.949 - - - - -
Beam Design 2020A134
6/11/2020 1
d = 13.250 in.
6/11/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [46.38 x (216.00 + 3)] x (12 in./ft.)3 = 5.88 ft3
Volumespan = N[A x L] = 1 x [46.38 x 216.00] x (12 in./ft.)3 = 5.80 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 5.88 = 201.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 5.80 = 198.3 lbs
Distributed Self Weight (ws) = = 11.02 plf
80 plf
80 plf
ws = 11.02 plf
18.00 ft.
17.75 ft.
18.25 ft.
1560.51 lbs
1560.51 lbs
6/11/2020 3
lu = Unbraced Length = 18 ft.
lu/d = = 16.30
le = 1.63lu + 3d = 1.63(216.0) + 3(13.25) = 391.83 in. = 32.65 ft.  (NDS Table 3.3.3)
Rb = = 20.59
 Rb = 20.59 < 50   ➜  OK
6/11/2020 4
FbE = = 1642.22 psi
CL =   = 0.949
Fbx' = (900)(1.00)(1)(1)(0.949)(1)(1)(1) = 853.8 psi
fb = = 811.6 psi
 fb = 811.6 psi < Fbx' = 853.8 psi  (CSI = 0.95)   ➜  OK
fv* = = 43.68 psi
 fv* = 43.68 psi < Fvx' = 180.00 psi  (CSI = 0.24)   ➜  OK
fv = = 49.78 psi
 fv = 49.78 psi < Fvx' = 180.00 psi  (CSI = 0.28)   ➜  OK
6/11/2020 5
ΔLL = = 0.17 in.
(L/d)LL = 216.00 / 0.17 = 1241
 ΔLL = 0.17 in = L/1241 < L/360   ➜  OK
ΔTL = = 0.37 in.
(L/d)TL = 216.00 / 0.37 = 580
 ΔTL = 0.37 in = L/580 < L/240   ➜  OK
fc⊥ = = 148.6 psi
 fc⊥ = 148.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.24)   ➜  OK
6/11/2020 6
