Size: 4 x 12
Design Span (L): 39.75 ft.
Clear Span: 39.50 ft.
Total Span: 40.00 ft.
Live Load: 15 plf
Dead Load: 0 plf
Selfweight: 371.8 lbs
Dist. Selfweight: 9.35 plf
Total Weight: 374.1 lbs
Incised Lumber: Yes
Notes: BEMA TO SUPPORT RAFTER ON COLUMNS SPACED EVERY 20FT.
CL Beam Stability Factor 0.947 - - - - -
CF Size Factor 1.1 1 - 1 - -
Beam Design RAFAEL ARROYO 300 DESIREE LANE RAFAEL SHED
6/8/2020 1
6/8/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (477.00 + 3)] x (12 in./ft.)3 = 10.94 ft3
Volumespan = N[A x L] = 1 x [39.38 x 477.00] x (12 in./ft.)3 = 10.87 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 10.94 = 374.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 10.87 = 371.8 lbs
15 plf
0 plf
ws = 9.35 plf
39.75 ft.
39.50 ft.
40.00 ft.
487.05 lbs
487.05 lbs
6/8/2020 3
lu = Unbraced Length = 20 ft.
lu/d = = 21.33
le = 1.84lu = 1.84(240.0) = 441.60 in. = 36.80 ft.  (NDS Table 3.3.3)
Rb = = 20.14
 Rb = 20.14 < 50   ➜  OK
6/8/2020 4
Eminy' = Eminy(CM)(Ct)(Ci) = 580000(1)(1)(0.95) = 551000 psi
FbE = = 1630.37 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(1)(1.1)(0.8)(1) = 910.80 psi
CL =   = 0.947
Fbx' = (900)(1.15)(1)(1)(0.947)(1.1)(0.8)(1) = 862.4 psi
fb = = 781.8 psi
 fb = 781.8 psi < Fbx' = 862.4 psi  (CSI = 0.91)   ➜  OK
Fvx' = (180)(1.15)(1)(1)(0.8) = 165.60 psi
fv* = = 17.57 psi
 fv* = 17.57 psi < Fvx' = 165.60 psi  (CSI = 0.11)   ➜  OK
fv = = 18.44 psi
 fv = 18.44 psi < Fvx' = 165.60 psi  (CSI = 0.11)   ➜  OK
6/8/2020 5
ΔLL = = 1.33 in.
(L/d)LL = 477.00 / 1.33 = 357
 ΔLL = 1.33 in = L/357 < L/180   ➜  OK
ΔTL = = 2.17 in.
(L/d)TL = 477.00 / 2.17 = 220
 ΔTL = 2.17 in = L/220 < L/120   ➜  OK
fc⊥ = = 46.4 psi
 fc⊥ = 46.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.07)   ➜  OK
6/8/2020 6
