Beam Design - RAFTER FORCES
Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Live Load: 30 plf
Dead Load: 15 plf
Selfweight: 79.2 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 80.2 lbs
Notes: SHED ADDITION TO EXISTING GARAGE
Beam Design RAFAEL ARROYO 300 DESIREE LANE RAFAEL SHED
6/8/2020 1
6/8/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (237.00 + 3)] x (12 in./ft.)3 = 2.34 ft3
Volumespan = N[A x L] = 1 x [16.88 x 237.00] x (12 in./ft.)3 = 2.31 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.34 = 80.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.31 = 79.2 lbs
30 plf
15 plf
ws = 4.01 plf
19.75 ft.
19.50 ft.
490.08 lbs
490.08 lbs
6/8/2020 3
fb = = 906.3 psi
 fb = 906.3 psi < Fbx' = 1035.0 psi  (CSI = 0.88)   ➜  OK
6/8/2020 4
fv* = = 38.93 psi
 fv* = 38.93 psi < Fvx' = 207.00 psi  (CSI = 0.19)   ➜  OK
fv = = 43.02 psi
 fv = 43.02 psi < Fvx' = 207.00 psi  (CSI = 0.21)   ➜  OK
6/8/2020 5
ΔLL = = 0.36 in.
(L/d)LL = 237.00 / 0.36 = 657
 ΔLL = 0.36 in = L/657 < L/360   ➜  OK
ΔTL = = 0.59 in.
(L/d)TL = 237.00 / 0.59 = 402
 ΔTL = 0.59 in = L/402 < L/240   ➜  OK
fc⊥ = = 108.9 psi
 fc⊥ = 108.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.17)   ➜  OK
6/8/2020 6
