Beam Design - Oplinger Basement Beams
Size: 8.75 x 15
Design Span (L): 28.62 ft.
Clear Span: 28.33 ft.
Total Span: 28.91 ft.
Bearing (lb): 3.5 in.
Live Load: 493 plf
Dead Load: 185 plf
Selfweight: 880.8 lbs
Dist. Selfweight: 30.77 plf
Total Weight: 889.7 lbs
CV Volume Factor 0.899b - - - - -
Beam Design Brian Beason Clancy MT 292
5/29/2020 1
b = 8.750 in.
d = 15.000 in.
A = 8.750 x 15.000 = 131.25 in.2
Sx = (8.750)(15.000)2/6 = 328.13 in.3
Sy = (8.750)2(15.000)/6 = 191.41 in.3
Ix = (8.750)(15.000)3/12 = 2460.94 in.4
Iy = (8.750)3(15.000)/12 = 837.40 in.4
5/29/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [131.25 x (343.46 + 3.5)] x (12 in./ft.)3 = 26.35 ft3
Volumespan = N[A x L] = 1 x [131.25 x 343.46] x (12 in./ft.)3 = 26.09 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 26.35 = 889.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 26.09 = 880.8 lbs
Distributed Self Weight (ws) = = 30.77 plf
493 plf
185 plf
  ws = 30.77 plf
28.62 ft.
28.33 ft.
28.91 ft.
10246.60 lbs
10246.60 lbs
5/29/2020 3
CV = = 0.899
CV = 0.899 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.899) = 2480.5 psi
fb = = 2654.4 psi
 fb = 2654.4 psi > Fbx' = 2480.5 psi  (CSI = 1.07)   ➜  NG
5/29/2020 4
fv* = = 105.80 psi
 fv* = 105.80 psi < Fvx' = 304.75 psi  (CSI = 0.35)   ➜  OK
fv = = 115.92 psi
 fv = 115.92 psi < Fvx' = 304.75 psi  (CSI = 0.38)   ➜  OK
5/29/2020 5
ΔLL = = 1.68 in.
(L/d)LL = 343.46 / 1.68 = 204
 ΔLL = 1.68 in = L/204 < L/180   ➜  OK
ΔTL = = 2.42 in.
(L/d)TL = 343.46 / 2.42 = 142
 ΔTL = 2.42 in = L/142 < L/120   ➜  OK
Ab = b x lb = 8.75 x 3.5 = 30.63 in2
fc⊥ = = 334.6 psi
 fc⊥ = 334.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.51)   ➜  OK
5/29/2020 6
