Beam Design - Oplinger Basement Beams
Size: 6.75 x 18
Design Span (L): 28.62 ft.
Clear Span: 28.33 ft.
Total Span: 28.91 ft.
Bearing (lb): 3.5 in.
Live Load: 493 plf
Dead Load: 185 plf
Selfweight: 815.3 lbs
Dist. Selfweight: 28.49 plf
Total Weight: 823.6 lbs
CV Volume Factor 0.906b - - - - -
Beam Design Brian Beason Clancy MT 292
5/29/2020 1
b = 6.750 in.
d = 18.000 in.
A = 6.750 x 18.000 = 121.50 in.2
Sx = (6.750)(18.000)2/6 = 364.50 in.3
Sy = (6.750)2(18.000)/6 = 136.69 in.3
Ix = (6.750)(18.000)3/12 = 3280.50 in.4
Iy = (6.750)3(18.000)/12 = 461.32 in.4
5/29/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [121.50 x (343.46 + 3.5)] x (12 in./ft.)3 = 24.40 ft3
Volumespan = N[A x L] = 1 x [121.50 x 343.46] x (12 in./ft.)3 = 24.15 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 24.40 = 823.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 24.15 = 815.3 lbs
Distributed Self Weight (ws) = = 28.49 plf
493 plf
185 plf
  ws = 28.49 plf
28.62 ft.
28.33 ft.
28.91 ft.
10213.55 lbs
10213.55 lbs
5/29/2020 3
CV = = 0.906
CV = 0.906 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.906) = 2499.7 psi
fb = = 2381.8 psi
 fb = 2381.8 psi < Fbx' = 2499.7 psi  (CSI = 0.95)   ➜  OK
5/29/2020 4
fv* = = 111.74 psi
 fv* = 111.74 psi < Fvx' = 304.75 psi  (CSI = 0.37)   ➜  OK
fv = = 124.82 psi
 fv = 124.82 psi < Fvx' = 304.75 psi  (CSI = 0.41)   ➜  OK
5/29/2020 5
ΔLL = = 1.26 in.
(L/d)LL = 343.46 / 1.26 = 272
 ΔLL = 1.26 in = L/272 < L/180   ➜  OK
ΔTL = = 1.81 in.
(L/d)TL = 343.46 / 1.81 = 190
 ΔTL = 1.81 in = L/190 < L/120   ➜  OK
Ab = b x lb = 6.75 x 3.5 = 23.63 in2
fc⊥ = = 432.3 psi
 fc⊥ = 432.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.67)   ➜  OK
5/29/2020 6
