Size: 5.5 x 13.5
Design Span (L): 12.38 ft.
Clear Span: 12.00 ft.
Total Span: 12.75 ft.
Bearing (lb): 4.5 in.
Live Load: 1233.6 plf
Dead Load: 454.9 plf
Selfweight: 215.4 lbs
Dist. Selfweight: 17.41 plf
Total Weight: 222.0 lbs
Beam Design Brent Jensen 2273 Daisy Trail, Forest Lakes, AZ 2020A119
5/19/2020 1
d = 13.500 in.
5/19/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [74.25 x (148.50 + 4.5)] x (12 in./ft.)3 = 6.57 ft3
Volumespan = N[A x L] = 1 x [74.25 x 148.50] x (12 in./ft.)3 = 6.38 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 6.57 = 222.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.38 = 215.4 lbs
1233.6 plf
454.9 plf
  ws = 17.41 plf
12.38 ft.
12.75 ft.
10875.16 lbs
10875.16 lbs
5/19/2020 3
fb = = 2345.6 psi
 fb = 2345.6 psi < Fbx' = 2760.0 psi  (CSI = 0.85)   ➜  OK
5/19/2020 4
fv* = = 174.47 psi
 fv* = 174.47 psi < Fvx' = 304.75 psi  (CSI = 0.57)   ➜  OK
fv = = 213.24 psi
 fv = 213.24 psi < Fvx' = 304.75 psi  (CSI = 0.70)   ➜  OK
5/19/2020 5
ΔLL = = 0.32 in.
(L/d)LL = 148.50 / 0.32 = 463
 ΔLL = 0.32 in = L/463 < L/240   ➜  OK
ΔTL = = 0.44 in.
(L/d)TL = 148.50 / 0.44 = 335
 ΔTL = 0.44 in = L/335 < L/180   ➜  OK
Ab = b x lb = 5.5 x 4.5 = 24.75 in2
fc⊥ = = 439.4 psi
 fc⊥ = 439.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.68)   ➜  OK
5/19/2020 6
