Size: 5.5 x 12
Design Span (L): 12.25 ft.
Clear Span: 12.00 ft.
Total Span: 12.50 ft.
Live Load: 1233.6 plf
Dead Load: 454.9 plf
Selfweight: 568.7 lbs
Dist. Selfweight: 46.42 plf
Total Weight: 580.3 lbs
Beam Design Brent Jensen 2273 Daisy Trail, Forest Lakes, AZ 2020A118
5/19/2020 1
5/19/2020 2
Volumetotal = N[A x (L + lb)] = 3 x [66.00 x (147.00 + 3)] x (12 in./ft.)3 = 17.19 ft3
Volumespan = N[A x L] = 3 x [66.00 x 147.00] x (12 in./ft.)3 = 16.84 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 17.19 = 580.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 16.84 = 568.7 lbs
Distributed Self Weight (ws) = = 46.42 plf
1233.6 plf
454.9 plf
  ws = 46.42 plf
12.25 ft.
12.50 ft.
10843.26 lbs
10843.26 lbs
5/19/2020 3
fb = = 986.2 psi
 fb = 986.2 psi < Fbx' = 2760.0 psi  (CSI = 0.36)   ➜  OK
5/19/2020 4
fv* = = 67.36 psi
 fv* = 67.36 psi < Fvx' = 304.75 psi  (CSI = 0.22)   ➜  OK
fv = = 80.50 psi
 fv = 80.50 psi < Fvx' = 304.75 psi  (CSI = 0.26)   ➜  OK
5/19/2020 5
ΔLL = = 0.15 in.
(L/d)LL = 147.00 / 0.15 = 1006
 ΔLL = 0.15 in = L/1006 < L/240   ➜  OK
ΔTL = = 0.21 in.
(L/d)TL = 147.00 / 0.21 = 715
 ΔTL = 0.21 in = L/715 < L/180   ➜  OK
fc⊥ = = 219.1 psi
 fc⊥ = 219.1 psi < Fc⊥x' = 650.00 psi  (CSI = 0.34)   ➜  OK
5/19/2020 6
