Grade: DF No.1
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 462.4 plf
Dead Load: 200 plf
Selfweight: 79.5 lbs
Dist. Selfweight: 10.25 plf
Total Weight: 82.0 lbs
Beam Design Brent Jensen 2273 Daisy Trail, Forest Lakes, AZ 2020A116
5/19/2020 1
5/19/2020 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (93.00 + 3)] x (12 in./ft.)3 = 2.31 ft3
Volumespan = N[A x L] = 3 x [13.88 x 93.00] x (12 in./ft.)3 = 2.24 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 2.31 = 82.0 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 2.24 = 79.5 lbs
Distributed Self Weight (ws) = = 10.25 plf
462.4 plf
200 plf
ws = 10.25 plf
7.75 ft.
7.50 ft.
2690.61 lbs
2690.61 lbs
5/19/2020 3
Fbx' = (1000)(1.15)(1)(1)(1)(1.1)(1)(1) = 1265.0 psi
fb = = 944.4 psi
 fb = 944.4 psi < Fbx' = 1265.0 psi  (CSI = 0.75)   ➜  OK
5/19/2020 4
fv* = = 75.24 psi
 fv* = 75.24 psi < Fvx' = 200.79 psi  (CSI = 0.37)   ➜  OK
fv = = 93.93 psi
 fv = 93.93 psi < Fvx' = 200.79 psi  (CSI = 0.47)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1700000(0.9)(1)(1) = 1530000 psi
5/19/2020 5
ΔLL = = 0.08 in.
(L/d)LL = 93.00 / 0.08 = 1125
 ΔLL = 0.08 in = L/1125 < L/240   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 93.00 / 0.12 = 773
 ΔTL = 0.12 in = L/773 < L/180   ➜  OK
fc⊥ = = 199.3 psi
 fc⊥ = 199.3 psi < Fc⊥x' = 418.75 psi  (CSI = 0.48)   ➜  OK
5/19/2020 6
