Size: 5.5 x 18
Design Span (L): 18.00 ft.
Clear Span: 17.50 ft.
Total Span: 18.50 ft.
Live Load: 1190 plf
Dead Load: 250 plf
Selfweight: 417.8 lbs
Dist. Selfweight: 23.21 plf
Total Weight: 429.4 lbs
CV Volume Factor 0.968b - - - - -
Beam Design Brent Jensen 2273 Daisy Trail, Forest Lakes, AZ 2020A113
5/19/2020 1
d = 18.000 in.
5/19/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [99.00 x (216.00 + 6)] x (12 in./ft.)3 = 12.72 ft3
Volumespan = N[A x L] = 1 x [99.00 x 216.00] x (12 in./ft.)3 = 12.38 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 12.72 = 429.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 12.38 = 417.8 lbs
1190 plf
250 plf
  ws = 23.21 plf
18.00 ft.
17.50 ft.
18.50 ft.
13534.70 lbs
13534.70 lbs
5/19/2020 3
CV = = 0.968
CV = 0.968 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.968) = 2672.6 psi
fb = = 2394.3 psi
 fb = 2394.3 psi < Fbx' = 2672.6 psi  (CSI = 0.90)   ➜  OK
5/19/2020 4
fv* = = 166.27 psi
 fv* = 166.27 psi < Fvx' = 304.75 psi  (CSI = 0.55)   ➜  OK
fv = = 199.53 psi
 fv = 199.53 psi < Fvx' = 304.75 psi  (CSI = 0.65)   ➜  OK
5/19/2020 5
ΔLL = = 0.58 in.
(L/d)LL = 216.00 / 0.58 = 370
 ΔLL = 0.58 in = L/370 < L/180   ➜  OK
ΔTL = = 0.72 in.
(L/d)TL = 216.00 / 0.72 = 301
 ΔTL = 0.72 in = L/301 < L/120   ➜  OK
fc⊥ = = 410.1 psi
 fc⊥ = 410.1 psi < Fc⊥x' = 650.00 psi  (CSI = 0.63)   ➜  OK
5/19/2020 6
