Design Span (L): 8.25 ft.
Clear Span: 8.00 ft.
Total Span: 8.50 ft.
Live Load: 320 plf
Dead Load: 80 plf
Selfweight: 66.3 lbs
Dist. Selfweight: 8.04 plf
Total Weight: 68.3 lbs
Beam Design 2020A109
5/18/2020 1
5/18/2020 2
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (99.00 + 3)] x (12 in./ft.)3 = 1.93 ft3
Volumespan = N[A x L] = 3 x [10.88 x 99.00] x (12 in./ft.)3 = 1.87 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 1.93 = 68.3 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 1.87 = 66.3 lbs
Distributed Self Weight (ws) = = 8.04 plf
320 plf
80 plf
ws = 8.04 plf
8.25 ft.
8.50 ft.
1734.15 lbs
1734.15 lbs
5/18/2020 3
Fbx' = (900)(1.00)(1)(1)(1)(1.2)(1)(1) = 1080.0 psi
fb = = 1056.7 psi
 fb = 1056.7 psi < Fbx' = 1080.0 psi  (CSI = 0.98)   ➜  OK
5/18/2020 4
Fvx' = (180)(1.00)(0.97)(1)(1) = 174.60 psi
fv* = = 66.05 psi
 fv* = 66.05 psi < Fvx' = 174.60 psi  (CSI = 0.38)   ➜  OK
fv = = 77.39 psi
 fv = 77.39 psi < Fvx' = 174.60 psi  (CSI = 0.44)   ➜  OK
5/18/2020 5
ΔLL = = 0.16 in.
(L/d)LL = 99.00 / 0.16 = 611
 ΔLL = 0.16 in = L/611 < L/360   ➜  OK
ΔTL = = 0.21 in.
(L/d)TL = 99.00 / 0.21 = 479
 ΔTL = 0.21 in = L/479 < L/240   ➜  OK
fc⊥ = = 128.5 psi
 fc⊥ = 128.5 psi < Fc⊥x' = 418.75 psi  (CSI = 0.31)   ➜  OK
5/18/2020 6
