Grade: DF No.1
Design Span (L): 8.25 ft.
Clear Span: 8.00 ft.
Total Span: 8.50 ft.
Live Load: 462 plf
Dead Load: 200 plf
Selfweight: 84.6 lbs
Dist. Selfweight: 10.25 plf
Total Weight: 87.1 lbs
Beam Design 2020A106
5/17/2020 1
5/17/2020 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (99.00 + 3)] x (12 in./ft.)3 = 2.46 ft3
Volumespan = N[A x L] = 3 x [13.88 x 99.00] x (12 in./ft.)3 = 2.38 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 2.46 = 87.1 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 2.38 = 84.6 lbs
Distributed Self Weight (ws) = = 10.25 plf
462 plf
200 plf
ws = 10.25 plf
8.25 ft.
8.50 ft.
2857.07 lbs
2857.07 lbs
5/17/2020 3
Fbx' = (1000)(1.15)(1)(1)(1)(1.1)(1)(1) = 1265.0 psi
fb = = 1069.5 psi
 fb = 1069.5 psi < Fbx' = 1265.0 psi  (CSI = 0.85)   ➜  OK
5/17/2020 4
fv* = = 81.26 psi
 fv* = 81.26 psi < Fvx' = 200.79 psi  (CSI = 0.40)   ➜  OK
fv = = 99.93 psi
 fv = 99.93 psi < Fvx' = 200.79 psi  (CSI = 0.50)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1700000(0.9)(1)(1) = 1530000 psi
5/17/2020 5
ΔLL = = 0.11 in.
(L/d)LL = 99.00 / 0.11 = 934
 ΔLL = 0.11 in = L/934 < L/240   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 99.00 / 0.15 = 642
 ΔTL = 0.15 in = L/642 < L/180   ➜  OK
fc⊥ = = 211.6 psi
 fc⊥ = 211.6 psi < Fc⊥x' = 418.75 psi  (CSI = 0.51)   ➜  OK
5/17/2020 6
