0 Members and 5 Guests are viewing this topic.
Version 1.4.4 - 06.17.2024
- Added the "Draw Service Entrance" function to the primary toolbar.
- Enabled the ability to draw service entrance devices: CSED and Meter Socket.
For the callout and 2D symbol I'm not really sure what I should use, for now I'm showing the device part number and a simple rectangle.  Any thoughts or suggestions in this regard will be appreciated.
Per customer request I also think it would be pertinent to add some disconnect/switches to the misc. tool. Typically in residential applications you will see these mounted externally for AC equipment or hot tubs. The more common ones are not too expensive so I thought it would be instructional to actually put my hands on some of these devices to better understand them and also for more accurate modeling reasons.
This is the 60A Square D QO200TRCP. I'm actually surprised at how sturdy this little enclosure is.
Version 1.4.5 - 06.19.2024
- Added "disconnect switches" under misc. fixtures.
- Added a twin meter socket to the built-in library.
- Updated the Legend tool to include service entrance devices.
- Updated the Electrical Estimating module to include service entrance devices.
- Added voltage and amperage as parameters for service entrance devices.
- Changed the label text for service entrance devices to voltage and amperage.
Version 1.4.6 - 06.22.2024
- Added "generators" under misc. fixtures.
- Added "water heaters" under misc. fixtures.
- Added a variety of other common electrical devices categories under misc. fixtures.
Version 1.4.7 - 07.18.2024
- Added combined "smoke/CO" detectors under safety devices.
- Updated the Legend tool to include combined smoke/CO devices.
The included device in the smoke/CO library is a KIDDE 30CUDR. Just bought this one yesterday and modeled it this morning.
https://www.amazon.com/dp/B0CX664SNZ
Note the 2D symbol text for this type of device is "SC".
I've had some call for AC condenser units, so I'm going to create some very generic low poly models to add into the built-in library.
Here is my first crack at a 30x30x40 unit (it is a solid group):
elec_su258_800
Let me know if there are any particular sizes or geometries you would like to see added.
Version 1.4.8 - 02.07.2025
- Added "hvac" under misc. fixtures.
- Added four generic hvac condensor units/sizes into the built-in library: 30X28, 30x32, 30x40, 36x32.
Version 1.4.9 - 02.11.2025
- Added three generic hvac condensor units/sizes into the built-in library (with WeatherGuardTM tops): 30X28_WG, 30x32_WG, 30x40_WG.
These additional variants added per customer request.  They are the exact same as the similar sized units other than the addition of the weather guard top.  Hopefully this gives enough selection for typical residential AC units however if there is need for any other styles etc... please let me know.
**Version 1.5.0** - 02.16.2025
- Added two generic side discharge hvac/heat pump condensor units into the built-in library: HP_XV19_42, HP_XV19_36.
- Added various "Wilkerson Art" framed art prints within the "art" category under misc. fixtures: Wasco, Frog, Hummingbird, Eagle under Sun, Killer Whale, Abstract and Medeek (Grizzly Bear).
http://www.wilkersonart.com
The funny thing is that I added the hummingbird framed art back in June (2024) as an Easter Egg but I guess no one noticed, or at least no one ever messaged me about it so I guess it went undetected.  I've also added in a decent wall clock as well for those needing a wall clock mounted in a room.
Decided to take a much needed break from the code today and did some other misc. tasks.  This one just kind of popped up on my radar so I figured I would add a few more framed prints.
As far as using the artwork in any of your projects, so long as you hold a licensed copy of the Medeek Electrical plugin you are authorized to use my artwork in any personal or professional projects you see fit.  My only request is that if you do decide to use the artwork, please give attribution where possible and applicable.
Version 1.5.2 - 06.02.2025
- Updated the wire library to include all the common NMB wire sizes.
Wire sizes per the Southwire (Romex) documentation:
http://design.medeek.com/resources/electricalplugin/references/2403_3-C_Romex_NMB_Cable_SpecSheet_Web.pdf
