Author Topic: Development and Updates for the Medeek Electrical Plugin  (Read 16760 times)
« Reply #90 on: April 12, 2019, 04:57:22 pm »
Version 1.0.5 - 04.12.2019
- Added the "Draw Legend" function to the secondary toolbar.
- Enabled the ability to automatically create an electrical symbols legend for all electrical devices within the model.
After working my way down through the list of possible symbols I'm surprised to see that there are so many and the legend can get quite large.
« Reply #91 on: April 13, 2019, 02:32:50 am »
I think the real power in this plugin is not the ability to insert 3D components into your model, technically you don't even need a plugin to do this, just a bunch of pre-configured components (.skp files).  The real strength is the automation of the 2D symbols and the parametrics of the plugin (allowing you to swap out devices types, colors, height and rotation).  Now with the addition of a parametric symbols legend it automates yet another tedious task.
I'm fairly happy with the way the legend has come out but for future work I may include a parameter in the global settings which allows the user to enable sub-titles (divides the legend into logical sections:  outlets, switches, lights, etc...) as well as specify the number of columns that legend should be divided into, this becomes more of an issue when there are a lot of electrical symbols to display.
I think some people would argue that I go too deep with my plugins (too many settings, parameters, options etc...)  I would agree that if possible simple is often better.  The goal is to make everything as simple as possible, but not simpler.
On the flip side the addition of more options and parameters increases the amount of data or information that model contains and hence makes it more useful (BIM).  Options also allow the user to further customize their workflow with the plugin and tailor it specifically to their needs.  Many of the options I have added have been directly requested by users of the plugins
« Last Edit: April 13, 2019, 02:46:59 am by Medeek »
« Reply #92 on: April 13, 2019, 03:26:16 am »
For those that are interested I will explain how the new "Draw Legend" tool works under the hood.
First the plugin finds all of the groups in the model (active_entities, if no group or component is open for editing then this will be the same as entities at the root of the model).
It then checks inside each of these groups and identifies the electrical groups that belong to the plugin (based on the group instance name).  Once it has collected up all of the electrical groups in the model it then divides them into their appropriate categories:  Outlets, Switches, Light etc...
It then examines each sub-category and dives into the attributes library for each electrical device (group).  The attributes library tells it what 2D symbol is associated with that particular device.  It then creates a  new list of symbols to draw for the legend for each category at the same time discarding or preventing duplicates.
The symbols shown in the legend are drawn, for the most part, using the same methods as the symbols drawn for the actual devices however some of them have been altered slightly in order to customize them specifically for the legend.
As you can see there is quite a bit going on under the hood.  When a model gets large with hundreds of walls and possibly hundreds of electrical components generating the legend may take up to 30 seconds.
« Reply #93 on: April 15, 2019, 06:29:39 am »
Version 1.0.6 - 04.15.2019
- Added additional NEMA 240V receptacles into the Outlet module: NEMA 6-30R, NEMA 6-50R.
These additional receptacles (and symbols) were per customer request.
« Reply #94 on: April 15, 2019, 10:34:37 am »
Tutorial 3:  Electrical Symbols Legend
« Reply #95 on: April 18, 2019, 07:12:59 am »
Since adding the symbols legend I've had a number of requests for a tool to draw a schedule (similar to how I am drawing the legend).
Now that I've got a fairly solid routine for pulling the electrical data (I will use much of this same code for the estimating tool) it isn't too big of a leap to draw a schedule.
My question is what information do you need or want in this schedule, how do you want it laid out?  Every device listed with its parameters or do I group like devices?
Please give feedback in this regard.  Also feel free to send me any sample electrical schedules that I can utilize as references.
If I know what I want to output I can probably knock this out in 2-3 hours, most of the underlying code is already in place.
« Reply #96 on: April 22, 2019, 09:13:07 am »
Looks like the listing is finally live in the Extension Warehouse:
https://extensions.sketchup.com/en/content/medeek-wall-plugin-1
« Reply #97 on: April 24, 2019, 07:49:02 am »
To celebrate the inclusion of this new extension into the Extension Warehouse and to further accelerate its uptake I will be running an Easter special.
This special is a little different than those I have recently done in the past.
In order to obtain a full license for the Electrical Extension at no cost all you need to do is renew one of your existing licenses for any other Medeek extension (Truss, Wall or Foundation).  Purchase of a new license for any of these three plugins is also a valid option as well.
Once you have purchased either a renewal or new license of the Truss, Wall or Foundation plugin(s) then please send me an email and I will issue you a license for the Medeek Electrical extension.  If you already own the electrical extension I will issue a renewal to your existing license, thereby extending it license expiration date an additional year.
If you renew more than one extension, only one renewal can be applied towards a free license or renewal of the Electrical extension.
This promotion is only valid for purchases and renewals from 04-24-2019 thru 05-01-2019, there will be no exceptions.
« Last Edit: April 24, 2019, 07:55:23 am by Medeek »
« Reply #98 on: April 28, 2019, 11:25:43 am »
Version 1.0.7 - 04.28.2019
- Fixed the show_modal bug for macOS in the Materials tab of the global settings.
« Reply #99 on: July 03, 2019, 12:53:26 pm »
As a celebration of the 4th of July and the full parameterization of the Foundation plugin I will be offering an incentive on new purchases or renewals of the Truss, Foundation or Wall plugins.
If you purchase or renew any of the BIM plugins on the 4th of July (tomorrow) you will be entitled to a complimentary license for the Medeek Electrical extension.  This promotion is only valid on the 4th of July.
I will be taking most of the day off tomorrow (finally) and eating some good food and watching some fireworks on the beach.
Happy 4th of July!
« Reply #100 on: September 07, 2019, 06:50:36 am »
A couple of things worth noting after working with a customer via Skype this morning:
1.) If your custom walls have reversed faces this will affect the plugin. The solution is to jump into the group, right click on the face in question and reverse the face.
2.) The plugin calculates the bottom of the wall by looking at the origin of the group that is the container for the wall geometry. If the origin of this group is below or above the bottom of the wall then the vertical distance for positioning various electrical fixtures (ie. switches, outlets, data etc…) will not be correct. I may change this up to consider the lowest point of the face rather than the origin of the group, I will need to give this some additional thought.
« Reply #101 on: September 13, 2019, 02:19:22 am »
For the month of September I will be running the following promotion:
If you purchase or renew any of the BIM plugins during the month of September you will be entitled to a complimentary license for the Medeek Electrical extension.  This promotion is only valid until September 30th.
Note, that if you already own an existing license for the electrical plugin then this promotion will allow you to further extend your license expiration of that plugin by an additional year.
If you purchased or renewed one of the other extensions in the previous two weeks (Sept 1 thru Sept 14) you are also retroactively eligible for this promotion, please contact me via email to take advantage of this offer.
« Reply #102 on: September 28, 2019, 11:00:52 am »
Version 1.0.8 - 09.28.2019
If you are noticing a slowdown of the plugin performance after multiple edits to an electrical fixture, this fix will resolve that issue.  This issue affects all previous versions of the plugin.
« Reply #103 on: November 19, 2019, 10:02:33 am »
I've had a lot of requests lately for floor mounted outlets.  I've gone ahead and created some low poly models of the Leviton series:
https://www.leviton.com/en/docs/Q-916A_Floor_Box_Assemblies_PB.pdf
View model(s) here:
https://3dwarehouse.sketchup.com/model/5584e79a-c9f2-44b8-b518-a62b3079fe7d/Medeek-Floor-Outlets
If there is interest in other brands of floor outlets please let me know.  The Hubbell-Raco (6224) also interests me but I haven't had a chance to create a model of it yet and I have been unable to find any detailed dimensional data on it:
https://www.hubbell.com/raco/en/Products/Electrical-Electronic/Floor-Boxes/In-Floor/6224/p/1530397
« Reply #104 on: November 19, 2019, 01:52:57 pm »
The second toolbar will now include an icon for floor mounted outlets:
