Author Topic: Development and Updates for the Medeek Wall Plugin  (Read 140214 times)
« Reply #705 on: September 14, 2020, 05:07:53 pm »
Version 1.6.6 - 09.15.2020
- Fixed a bug with Tyvek and ZIP Systems sheathing when the sheathing is lapped at the corners (rectangular walls only).
« Reply #706 on: September 26, 2020, 10:30:38 am »
Version 1.6.7 - 09.26.2020
- Added additional tool tips to the Wall Corners tab of the Global Settings.
I've been fielding a lot of questions recently about the corner offset parameter and related wall end/corner conditions.  I may need to still provide additional documentation and diagrams to further clarify these parameters.
« Reply #707 on: September 28, 2020, 11:19:26 am »
Version 1.6.8 - 09.28.2020
- Added a "Refresh Licensee Data" button within the License tab of the Global Settings.
Previously when you renewed your license you would need to go through some convoluted steps to refresh you license data within the plugin.  This new feature reduces this process to a single mouse click.
Previously the required steps were:
1.) Remove the existing serial number.
2.) Click the Save Settings button.
3.) Re-enter your serial number.
4.) Click the Save Settings button again.
5.) Restart SketchUp.
Offline Greto1981
« Reply #708 on: October 09, 2020, 08:34:01 pm »
I just installed the Wall, Truss, & Foundation Suite. It's not producing (layers) now called tags in my version of 2020 Pro! Any suggestions?
« Reply #709 on: October 09, 2020, 08:41:26 pm »
You need to turn on the layers feature.  To do this navigate to the Layers tab of the Global Settings of the plugin(s).
« Reply #710 on: October 16, 2020, 02:24:55 pm »
First look at a 3D batten cladding on rectangular walls:
https://3dwarehouse.sketchup.com/model/5e43daf3-c604-49b7-82d6-95dfbc76563c/Batten-Test-1
« Reply #711 on: October 17, 2020, 03:21:34 am »
Some more screenshots of battens:
*Notice the format of the batten material and its three numeric values within the name of the material.
« Reply #712 on: October 17, 2020, 03:43:40 am »
Texture vs. 3D Battens:
Personally I prefer the texture myself, lower poly and it looks just as good or better than the real deal.
« Reply #713 on: October 17, 2020, 07:24:18 am »
Version 1.6.9 - 10.17.2020
- Added the ability to create custom "Board and Batten" wall cladding materials within the Material Library.
- Enabled "3D" Board and Batten wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
For the plugin to recognize the wall cladding material as a "board and batten" material is must be in this format:
battens_{decimal value}_{decimal value}_{decimal_value}
The three values are:  batten spacing, batten width, batten depth respectively.
There should be no white spaces inserted into the name, only the underscore character in three places as shown.
« Reply #714 on: October 18, 2020, 07:01:25 am »
Another view of board and battens:
Just over five years into programming these plugins, I released the first version of the Truss plugin Oct. 7, 2015.
The further I go it seems like I just keep coming up with more things "todo".  I really need to take myself and clone me about five times and then set each clone at developing the various plugins, maybe then I might get somewhere with all of this.
« Reply #715 on: October 23, 2020, 10:14:40 am »
Version 1.7.0 - 10.23.2020
- Fixed a bug in the Walls tab of the Global Settings.
Offline whiteoak
« Reply #716 on: October 26, 2020, 03:17:08 am »
I’m getting some glitches when drawing walls where they’ll randomly begin to appear at the 0,0,0 coordinate origin instead of where they’re being drawn. If I sometimes undo, click off the wall tool to another random drawing tool, draw a line or something, and then go back to the wall tool, the wall will end up drawing correctly. I’ve been unable to get a gable wall to draw correctly, however. It seems like this just started with the most recent SketchUp Pro update.
« Reply #717 on: October 26, 2020, 03:37:12 am »
If you've recently update the Wall plugin from a version prior to Version 1.4.0 then I strongly advise to reset your global settings in the General Tab of the Global Settings.  If this does not resolve the issue then turn on the Ruby Console and duplicate the error and then email me the error codes generated (nathan@medeek.com).
Offline whiteoak
« Reply #718 on: October 26, 2020, 04:20:53 am »
Thanks, I’ll try that out. Sounds like I must have missed some guidance on that.
