Author Topic: Development and Updates for the Medeek Foundation Plugin  (Read 82995 times)
« Reply #225 on: April 27, 2020, 10:20:57 am »
Version 1.5.8 - 04.27.2020
- Added a Global Reset button in the General tab of the Global Settings.
- Plugin files switched from .rbs to .rbe encryption.
« Reply #226 on: May 15, 2020, 06:55:28 am »
Version 1.5.9 - 05.15.2020
- Fixed a bug when the Auto Assign Materials parameter was turned off.
« Reply #227 on: May 28, 2020, 05:00:15 am »
Version 1.6.0 - 05.28.2020
- Added a footing concrete layer in the Global Settings under the "Layers" tab.
- Fixed a bug for metric templates with the strip footing tool and the polyline stemwall tool.
Note, that if you want the footing concrete layer to remain the same as the rest of the foundation (ie. stemwall) you can always assign it to the same layer name: "fnd_conc"
Also note, that any and all of these layer names are user configurable, the names shown are just default names I have assigned, the user can utilized their own naming convention that suites their workflow.
« Reply #228 on: August 29, 2020, 11:15:05 pm »
After giving this suggestion some additional thought:
I think I will introduce two additional parameters for stemwall foundations which will make them more applicable for use as retaining walls in foundation design.
The two parameters will be:
Ftg. Bar Development:  None, Hook, Full Ext., Full Int.
Ftg. Offset: 0.0 in (default)
Currently footings are drawn symmetrically with respect to the foundation wall, this will enable the user to offset the footing in or out (+/-).
« Reply #229 on: August 31, 2020, 02:30:21 am »
Version 1.6.1 - 08.31.2020
- Added a footing offset parameter to polyline stemwalls.
- Enabled options for 90 deg. footing hooks for vertical rebar in polyline stemwall.
https://3dwarehouse.sketchup.com/model/eb2be1c5-68b8-492a-a784-a31b68d46b5d/Asymmetric-Stemwall-Foundation
« Reply #230 on: October 09, 2020, 01:34:28 pm »
Version 1.6.2 - 10.09.2020
« Reply #231 on: October 22, 2020, 02:10:21 pm »
Version 1.6.3 - 10.22.2020
- Fixed a bug in the strip footing "Outline" edit menu.
« Reply #232 on: January 11, 2021, 11:25:59 am »
Version 1.6.4 - 01.11.2021
- Added the option for post bases for the (Post & Beam) Interior Bearing tool: BC40, BC60.
Post base hardware added per customer request.
« Reply #233 on: January 13, 2021, 04:21:56 pm »
Version 1.6.4b - 01.14.2021
- Added the following additional post bases to the Interior Bearing tool: ABU44, ABU66.
Two additional post bases added per customer request.
« Reply #234 on: February 09, 2021, 07:34:10 am »
When the foundation segment lengths in a polyline stemwall foundation are too short this is what you get (notice the anchor bolt placement):
I'm working up some additional logic to properly deal with anchor bolt placement with short segment lengths.
« Reply #235 on: February 09, 2021, 04:20:53 pm »
Version 1.6.5 - 02.09.2021
- Fixed a bug with anchor bolt placement for polyline stemwalls.
- Added an option for a zero depth footing for polyline stemwalls, which eliminates the footing for this foundation type.
By setting the depth of the footing to zero you can eliminate the footing from a polyline stemwall, so only the stemwall portion of the foundation is drawn.  This is per customer request.
Also the algorithm for anchor bolt placement for polyline stemwalls is greatly improved, however there can always be further improvements, any feedback is always appreciated.
« Last Edit: February 10, 2021, 04:02:52 am by Medeek »
« Reply #236 on: February 12, 2021, 01:44:12 pm »
Version 1.6.6 - 02.12.2021
- Added logic to the final assembly routine to allow for electrical components (Medeek Electrical) to be retained within all foundation assemblies.
