Author Topic: Development and Updates for the Medeek Truss Plugin  (Read 358496 times)
« Reply #690 on: October 11, 2019, 06:21:03 pm »
Another variation of the gable roof study:
Gables ad infinitum...
The one thing that jumps out here is that gable roof planes cannot be adjacent to each other (or other variants like dutch gable or half hip configurations), gable roof planes are separated by hip planes.  Additionally, I will limit the gable option to orthogonal roof planes only (corners must be 90 or 270 degrees).
There is always on more thing to add, at some point I hope to have conquered this beast.
« Reply #691 on: October 11, 2019, 07:04:19 pm »
When you raise the fascia line along a segment of the roof inevitably it must return to same level since a roof is a closed loop.  See model here:
https://3dwarehouse.sketchup.com/model/a87657fc-f488-47b9-9e40-b8767b4d4182/Roof-Study-11
I think I can make this work but I'm going to have to drastically change my algorithms to allow for unequal fascia/gutter lines.
The other interesting thing with all of this is that the fascia line could step up and down multiple times around a roof.
Another observation is that only hip roof planes technically step up or down, gable roof planes/edges are controlled by the adjacent hips.
« Last Edit: October 11, 2019, 07:07:25 pm by Medeek »
« Reply #692 on: October 12, 2019, 04:17:04 pm »
A couple of interesting gable roofs:
Looks like I have the roof primitive working for "interior" gables.  Now I just need to sort out the details for sheathing, cladding, sub-fascia and gutters.  An interior gable is defined as a gable roof plane with one or more corner angles of 270 degrees (orthogonal inside corner), hence an interior gable.
For now I'm not going to allow interior dutch gables or half hips.  As long as the angles, at both corners, are 90 degrees then you will be able to place a dutch gable or half hip on that roof plane.  However, the gable is a little more flexible and will allow some interesting configurations, as shown.
« Reply #693 on: October 13, 2019, 10:32:44 am »
Notice how the sheathing is now projecting underneath the gable overhangs:
Now I just need to get the cladding to behave similarly and then a few adjustments to the sub-fascia and gutters.
« Reply #694 on: October 13, 2019, 12:25:18 pm »
First look at cladding correctly displaying for interior gables:
The sub-fascia for interior gables is interesting because in most cases one or both side will die into another roof plane, however this is not always the case as can be seen in the example to the far left.  Logic to include all of these possibilities now must be constructed.
Unlike the much simpler exterior gable the position of the peak of the interior gable roof has no direct relation to the perimeter points that define this gable's edge.  Due to this inconvenience I cannot (easily) mathematically calculate the sub-fascia, I must use the roof primitive geometry to derive the correct points and position, again more emergent behavior.  In short, the roof primitive is smarter than I am.
« Reply #695 on: October 14, 2019, 07:26:26 am »
First look at sub-fascia for interior gables:
Bit of a struggle to consider all of the possible permutations for this type of roof but I think I have finally arrived at a robust solution.
I just need to consider gutters and then we can proceed with the actual framing of the roofs.
I've also heavily modified my error checking code for the roof primitive to make the overall performance more robust.  With the addition of interior gables there is more probability that the designer can create roof design that does not have valid geometry.  Further testing will be required to try and eliminate these scenarios or further augment the areas that are having trouble with these situations.
« Reply #696 on: October 14, 2019, 01:47:04 pm »
Version 2.5.7 - 10.14.2019
- Allowed the option for interior gables within complex roofs.
- Fixed a bug in the gutter module for complex roofs.
I need to do some traveling in the next few days but I just wanted to get the update out the door before taking a break from the code.
https://3dwarehouse.sketchup.com/model/fc818a82-d981-456b-b506-fe654d41cc74/Complex-Roof-11-Gutters-with-Interior-Gables
« Reply #697 on: October 14, 2019, 06:14:48 pm »
As I'm taking a break from the code before my trip it dons on me that the soffit & fascia, primarily the fascia is probably more important than the actual roof framing right now.  If I have that feature enabled it will allow the designer to complete his or her elevations.  Whereas the framing is a critical future feature but does not really come into play for the actual construction documents.
With that in mind, I think my next big push will be to complete the soffit & fascia, then I will begin the framing algorithms.  The good news is that the fascia algorithms will be very similar to the sub-fascia so most of my work there is already done.
Also speaking to a number of plugin clients earlier today it  took me back at how many of them actually use AutoCad for their construction documents, and just import parallel projections from SketchUp as a DXF/DWG.  Even though the resulting mess of  "dumb lines" in your AutoCad drawing is not optimal I suppose it is still quicker and easier to do this rather than to try and actually draw a complex roof elevation from scratch.
« Reply #699 on: October 15, 2019, 05:00:30 am »
I will be out for 2 - 3 days however you can probably reach me by phone if it is an emergency, however I won't have any computer in front of me so it may be hard to do any significant support or troubleshooting.
I had an interesting conversation with a client today and he wondered if I disliked engineering, and that is why I am now developing plugins.  I do not  dislike engineering, in fact I really would like to get back into it  but I would like to get back into it with SketchUp and my plugins leading the charge.
The one problem I have with the way residential engineering is done (or at least the way I was doing it), is the lack of automation.  Yes, there are plenty of tools out there (spreadsheets, Forte etc...) that help with the calculations, however I want something even more streamlined.  I want a program that already takes a 3D model of a structure and then is somehow smart enough to propagate the loads throughout that structure and run all the numbers automatically.  This is the way engineering should be done in the 21st century, we have the computers, and yes we have the technology, we just need to leverage it so that we can stop wasting our time on tedious chores.
To be honest, most of residential engineering is quite mundane.  There is some engineering judgement that comes into play in certain situations however for the most part it is merely taking some inputs and running them through a number of AWC and ASCE equations and giving the result a GO or NO-GO.  This is exactly what computers were built for.
This is my **vision** for the engineering module and what it should be able to do:
I should be able to enter the site criteria for a project and then with the push of a single button crunch all of the engineering calcs for that model.  The items that fail will be flagged.  I modify those items accordingly (upgrade a header to a larger size), and then run the numbers again, until everything passes.  I then click the generate report, a PDF is generated.  I review it one last time, checking for errors and making sure all the inputs and outputs look reasonable and consistent, and then print out a paper copy, and stamp and sign it.
I've decided my time is much better spent developing a proper solution like this rather than continuing my practice of manually crunching numbers for local residential clients.  Undoubtedly, I would make more money working on local engineering projects than I would make working on just these plugins (full time).  In fact, I even turned down an employment opportunity last year for a really nice, six figure income so that I could specifically pursue the Wall plugin full time.
Currently I'm probably only making only about half of what I could make working strictly as a conventional engineer or corporate drone, but with me it has never been about the money.  One has to look at the big picture with these things.  I love what I do, I have full ownership, and I am able to help hundreds, maybe thousands of architects, engineers and designers rather than just a handful of local clients.  Every day I wake up I get to decide what needs to done, I control the direction I take, even though my customers do guide me.  I am also able to leverage both my love for programming and my love of engineering.   I didn't choose this path, it chose me.
« Reply #700 on: October 19, 2019, 04:52:42 am »
First look at fascia with complex roofs:
https://3dwarehouse.sketchup.com/model/69ec1101-1f37-4689-bc60-f1633154495d/Fascia-Test-1
Now I just need to look at the various permutations for various roof end configurations (ie. gable, half hip, dutch gable).
With gable and half hip configurations we also have Boxed, Angled or Gable style configurations.
« Reply #701 on: October 20, 2019, 11:50:45 am »
First look at a half hip fascia and rake with a boxed soffit:
« Reply #702 on: October 21, 2019, 04:28:17 am »
First look at the soffit on a complex roof:
Unlike the sub-fascia and fascia the soffit (and its miter cuts) are also a function of the overhang at each roof plane, therefore the computation of the correct width of the soffit is a bit more complicated with asymmetric pitches.
The example shown is a symmetric roof with hips all the way around.  The inclusion of gables, dutch gables and half hips along with the soffit box extension parameter makes for a much more complicated problem.
« Reply #703 on: October 22, 2019, 03:33:43 am »
First look at a soffit on a complex hip roof with asymmetric roof planes:
https://3dwarehouse.sketchup.com/model/4f9ea5e8-4a31-469c-81be-fbf0ce366596/Soffit-Test-2
Now I just need to complete the special cases situations for half hips, dutch gables and gables.  Still quite a bit of work to do with soffits and also some more work on the fascia for the boxed end case (return and triangular pieces).
« Reply #704 on: October 23, 2019, 11:21:52 pm »
First look at a complex roof with a gable end and soffit and fascia:
I'm really trying to wrap up the soffit and fascia and get a new version released however there are a lot of details and possible geometries with the soffit and fascia when you throw gables, dutch gables and half hips into the mix.  The interior gables also further complicate the matter with a number permutations that must be specifically accounted for.
I probably have at least another day of adding in more logic for all of these possibilities, but I am getting close.
Rather than moving on to the actual framing I think I will spend a little time on roof connections and what I call a "terminal" roof configuration.  The terminal roof configuration is similar to the other configurations in that it can only be applied to a roof plane that has corner angles of 90 degrees.  I will allow the roof to just end (ie. no gable overhang), this will be useful when creating roofs that are adjacent to walls and other structures.
On a different note, I will be temporarily removing the "angled" option from the soffit type selection options.  This soffit configuration makes the most sense with simple gable roofs but with hip roofs it is a bit of a mess.  Until I study this further and make sure that I have a sensible solution I am limiting the soffit types to gable and boxed.
