0 Members and 33 Guests are viewing this topic.
I added the  porch roof using the hip roof and shed roof primitives.  I'm wondering if it might not be worthwhile to add in a feature to create this type of combination roof automatically.  Shed Roof w/ ledger & hip ends.
View updated model here:
https://3dwarehouse.sketchup.com/model.html?id=uf979b67e-2755-4981-9bfc-06d20b64d313
Note, how close the ledger is to the rim joist.  The porch roof diaphragm will actually stiffen up the region of the wall where the stairway is to some extent, in general the use of a "wind beam" is probably advisable if platform framing is used and a quick check of the numbers should be done.
Started the manual as a MS Word document however that did't work so well for hyperlinks.  Starting over with an html manual page:
http://design.medeek.com/support/trusspluginmanual/mainpage.html
Couple of pages up, only about 25 more to go...
Version 1.2.9 - 02.12.2015
- Added Shed Rafter Roof (all advanced options enabled).
- Added ceiling joist option for Shed Rafter Roofs.
- Initial menu now defaults to last picked option of session for that sub-menu item.
A typical application might be a clerestory roof with a upper shed roof and lower shed roof with a ledger board:
https://3dwarehouse.sketchup.com/model.html?id=u0b2dd5bc-605d-467c-a6bb-449bb54e76e6
Version 1.3.0 - 02.14.2016
- Added tail bearing truss type, configurations: (Fink).
- Metric input enabled for tail bearing truss type.
- Advanced options enabled for tail bearing truss type.
https://3dwarehouse.sketchup.com/model.html?id=u704b9d92-bd38-4895-b71b-19691f31cca7
I have shown 3 configurations of the same roof to display the differences with non-structural vs. structural outlookers (horz. & vert.).  I am not exactly sure how to treat the gable end truss for this truss type since I have never dealt with this type of truss before.  Any sample outputs showing the gable end truss with a dropped top chord for a tail bearing truss would be very helpful.
#125
I am currently investigating the best method to construct the gable end wall and truss with a tail bearing truss.  Show below are 3 different possible configurations:
1.) Structural Outlookers (Vertical)
2.) Non-Structural Outlookers (Horizontal)
3.) Structural Outlookers (Horizontal)
This is just one possible method of framing the gable end wall into the gable truss with a 2x4 outlooker.  Option 3 shown above is somewhat of a question, not sure how that heel joint would come together.
View the model here to analyze the different configurations:
https://3dwarehouse.sketchup.com/model.html?id=u75c42456-c8e5-4002-bc93-779860f8dc61
Alternatively one could balloon frame the wall at the gable ends and attach a ledger for the ceiling:
https://3dwarehouse.sketchup.com/model.html?id=ub1aa30d4-a7c3-4320-8bc4-03fd128b5913
In my opinion a partially sloping wall gets complicated to frame.  From an engineering standpoint the balloon framed wall is also the strongest option.
Version 1.3.1 - 02.15.2016
- Added Triple Fink and Quad Fink common truss types.
- Structural outlookers (vert. & horz.) enabled under advanced roof options for Common (Triple & Quad Fink) truss types.
Triple Fink @ 70' w/ 2x6 chords
Quad Fink @ 80' w/ 2x6 chords
https://3dwarehouse.sketchup.com/model.html?id=u2b57ed6d-9f1f-47c4-9e09-5489940c94b2
I've been looking at a number of garage designs recently that employ an attic or storage truss.  I'm finding that a lot of them tend to use raised heels to allow for more head room while having a lower roof pitch (ie. 6/12 - 8/12).  I'm thinking about adding in raised heels for the attic truss type in the plugin.
A quick mock up would look something like this:
https://3dwarehouse.sketchup.com/model.html?id=u208d64e3-ddcf-4923-8dfb-d507185fa663
Ignore the unbalance in the panel lengths, in practice and in the plugin they will be properly balanced.
What I do have a question on is the use of a top chord splice as shown in the above image so that the overhangs do not have to be as deep as the top chord in the non-triangulated region of the truss.  I have never seen a splice used on a attic truss with a raised heel, I don't see why it can't be done but it is always nice to have a confirmation that someone else is doing this sort of thing in practice.
Version 1.3.1 - 02.17.2016
- New submenu item and toolbar icon added for global settings.
Started to code in the dual pitch truss, the top chords, king post and bottom chord are there just need to add some webs:
Just an FYI, my previous post in Nov. had a sign switched in the last step of the derivation for Span 1, corrected in the plugin to a minus sign and everything is comes out perfect.
Here is a Dual Pitch 2/2 - 3/3 truss with a 12:12 pitch and a 4:12 pitch.
Still working on the gable end trusses and the advanced options involving structural outlookers.
I will be looking at raised heel scissor trusses next, those sound challenging and interesting.  Please post or send me examples of any raised heel scissor truss examples or shop drawings.  The combined pitches of the top and bottom chord with a wedge, slider or vertical web and strut will require some serious calculations and ample logic.
#132
Version 1.3.2 - 02.23.2016
- Added Dualpitch truss type, configurations: (2/2-3/3).
- Metric input enabled for dualpitch truss type.
- Advanced options enabled for dualpitch truss type.
https://3dwarehouse.sketchup.com/model.html?id=u9b6a5e53-76c4-4c9b-bce3-aaa8ffba4c36
A quick study of the general shape and layout of a 6/6 bowstring truss with different radii:
