Medeek and 82 Guests are viewing this topic.
Version 3.5.3 - 03.06.2024
- Added a "Panel" corner treatment for "End" and "Terminal" wall corners (rectangular walls only).
- Fixed a javascript bug for window and door presets.
- Fixed a bug with the door casing (custom casing options) and end cripple studs for pocket doors.
- Rearranged the door casing section of the door Draw and Edit menus.
- Fixed a bug with the advanced options for all wall types when using metric templates.
With this release I've fixed a number of substantial bugs that were discovered by users and also one by myself.  I highly recommend upgrading to this latest release of the plugin.
Version 3.5.4 - 03.08.2024
- Enabled an end grain material for top and bottom plates of rectangular walls.
- Fixed a javascript bug for garage door presets.
- Fixed a bug with door presets when using metric templates.
Version 3.5.4b - 03.09.2024
- Enabled a pressure treated end grain material for bottom plates of all walls.
- Enabled end grain materials for in-wall columns.
- Enabled end grain materials for beams.
- Enabled end grain materials for blocks.
- Enabled end grain materials for posts.
Version 3.5.5 - 03.11.2024
- Added a "Custom Glass" garage door type/option with fully customizable glass panels.
- Further refined the end grain material positioning for top plates (rectangular walls) and in-wall columns.
I will need to create a tutorial video explaining the proper syntax for the "Glass List".
Medeek Wall Plugin **Tutorial 47** - Custom Glass Garage Doors (w/ Webcam)
In the next update I will be adding a "taped" drywall/gypsum material option:
This is primarily for garages and other semi-finished spaces, so that a more realistic look is obtained.  The tiling of the gypsum is 4x8 sheets oriented horizontally.  The texture is mostly seamless, so I am fairly pleased with it.  If there is further interest I could also provide a 4x12 option as well, but for now I feel like the 4x8 option is probably the most standard and should suffice for most projects.
#1116
Version 3.5.6 - 03.21.2024
- Added built-in "Taped" and "Green Taped" gypsum materials for all wall types.
- Updated and added additional tool tips within the Global Settings.
Version 3.5.7 - 04.17.2024
Version 3.5.8 - 04.25.2024
- Fixed a bug with cripple studs over windows and doors.
- Fixed a bug with the copy wall tool.
Version 3.5.9 - 05.01.2024
- Added a rainscreen option for gable walls (vertical, horizontal, 45 and 135 degree).
- Added a rainscreen option for shed walls (vertical, horizontal, 45 and 135 degree).
- Added a rainscreen option for hip walls (vertical, horizontal, 45 and 135 degree).
- Updated the license verification system with a more secure and improved algorithm.
