0 Members and 7 Guests are viewing this topic.
Version 3.0.9 - 01.05.2023
- Enabled beam pockets (in-wall columns) for CMU, CMU Core and ICF walls.
- Fixed a bug within the plan view auto-dimensioning module having to do with in-wall columns.
- Fixed a minor typo in the Draw menu for in-wall columns.
Version 3.1.0 - 01.11.2023
- Enabled layer control integration with the Medeek Project extension.
- Moved the Medeek Estimating module to the Medeek Project extension.
- Moved the Medeek Documents module to the Medeek Project extension.
Version 3.1.1 - 01.19.2023
- Fixed a bug with ICF Walls.
- Fixed a type in the HTML of the General tab of the Global Settings.
Tutorial 32 - Auto-Dimensioning (9:31 min.)
Tutorial 33 - ICF Walls (5:51 min.)
Version 3.1.2 - 02.05.2023
- Fixed a bug with metric templates that propagated from Version 3.0.8.
- Fixed a specific bug with auto-loading wall presets.
! ATTENTION !
Critical bug fix, especially for metric templates.  I highly recommend upgrading to Version 3.1.2 if you have installed Version 3.0.8 or later.
The auto-load bug has to do with enabling the auto-load preset option in the Global Settings and then subsequently deleting the preset that was selected as the default auto-load preset.
Version 3.1.2b - 02.07.2023
- Fixed a minor bug with the Wall Selector Matrix (Gable, Shed and Hip walls).
This bug was due to some consolidation and general house cleaning I did with the code a few cycles back.  Even when a gable wall was selected it would automatically revert to a rectangular wall.  I just noticed this yesterday but the bug probably has been around for at least a month.
Version 3.1.3 - 02.16.2023
- Fixed a bug with door presets within the Edit Door menu.
Version 3.1.4 - 03.12.2023
- Added the following door types: flat one panel (single and double).
Version 3.1.5 - 03.17.2023
- Added a fluting number parameter for classical columns.
Really wasn't wanting to dig into this right now but after a quick inspection of my code I realized it would only take me a few minutes to add in this additional parameter so that one could fine tune the look of the fluting of classical columns.
I thought I would circle back to inclined walls since I had some questions on shed dormers over the weekend.
I've updated the wall menus to include these new parameters now I just need to create the boolean logic to modify the wall geometry accordingly:
This feature should give the user the flexibility to modify rectangular, hip, shed or gable walls as needed when an inclined bottom plate is required.
Version 3.1.6 - 03.26.2023
- Added inclined walls for all wall types: rectangular, shed, gable and hip.
This new feature can also be used on CMU, ICF and CMU CORE walls.
