Materials libray sorting
Started by buffalosky, February 18, 2024, 10:03:00 AM
buffalosky
Is there any way to sort the materials library list in "Wall" extension?
Adding a new one places it at the bottom of a long list.
Currently there is no way to sort however, if you really must sort the list you can actually edit the text file that contains the custom materials.  Editing this list can be done with any text editor like Notepad.
The material library config file can be found here:
C:\Users\%Username%\AppData\Roaming\Medeek\2023\medeek_wall_ext\library_mats
The file is called MATERIAL_LIBRARY.txt
Just be sure to leave a carriage return after the final material in the list so in case you add any new materials the plugin adds the new material to a new line.
