0 Members and 62 Guests are viewing this topic.
Version 1.1.8 - 12.21.2018
- Enabled temporary (construction) dimensions for all foundation types.
- Licensee name now appears in the License tab of the Global Settings when plugin is registered.
Version 1.1.8b - 12.28.2018
- Fixed bug in the registration/licensing module.
Callouts (label, area, volume) are now working for the  Slab-on-Grade foundation type (rectangle, polygon and face):
Now I just need to add the stats tabe into the attributes and then we can also bring this data into the Medeek Estimator module.
I think it would also be useful to quantify the rebar and provide the size (dia.) and total lineal feet for each size used.  For the wires mesh I'm assuming that number would be a sqft (area) but I'm not sure whether to provide the area which includes my (inside) offset or just the total area of the slab itself.
Anchor bolts are easy (size and qty.)
All also have the FPSF option which includes foam around the perimeter of the foundation.  I'm assuming this number would probably be the thickness and sqft (area)?
Note that the area dimension is the total area of the slab per its outer perimeter, so a garage curb will not change this number.
Version 1.1.9 - 01.03.2019
- Foundation and Footing labels option added to the General tab of the Global Settings.
- Foundation and Footing label prefixes can be customized in the General tab of the Global Settings.
- Foundation labels enabled for slab-on-grade foundations.
- When construction callouts are enabled the overall area and volume (concrete) of the foundation is displayed beneath foundation label (currently only slab-on-grade foundation assemblies have this feature available).
- Added customizable colors for lumber, PT Lumber and labels within the Materials tab of the Global Settings.
- Added additional layers for dimensions, annotations, 2d geometry, building code and engineering.
The customizable colors for the lumber (PT) will not take affect until I update the stemwall module.  Currently the color of the lumber is still hard coded into this module.
I am also working on an update to the Medeek Estimator which will then allow the user to quantify foundations as well as roof and wall assemblies.
So far I have the concrete, rebar, and anchor bolts queued up for analysis in the estimator module.  I will need to still work on adding in the insulation (foam) for the FPSF option.  The first foundation type that will be made available in the estimator is the slab-on-grade.  Once I am satisfied with the integration between the two plugins I will continue to flesh out the rest of the foundation types.
The bigger issue right now is the lack of parametrics for this plugin.  With the addition of the attribute library I am one step closer to making this happen.  There is really nothing special that needs to happen it is just a matter of pulling together the HTML menus and other tedious tasks within the Ruby code.
I apologize that it has taken this long to begin to address the parametrics issue.  As can be seen in the changelog I had a burst of activity in 2017 and then only recently began to slowly process other updates.
http://design.medeek.com/resources/foundationpluginchangelog.html
Most of my time has been spent on the other two plugins but it is my goal this year to bring this plugin up to par with the other two.
Version 1.2.0 - 01.06.2019
Estimating data for slab-on-grade foundations is now available with Version 0.9.9w of the Wall plugin.
Version 1.2.1 - 01.20.2019
Version 1.2.2 - 02.25.2019
Version 1.2.3 - 03.15.2019
First look at the new edit menu for slab on grade foundations:
Version 1.2.4 - 06.26.2019
- Enabled the "Edit SOG Assembly" function/menu for rectangular slab-on-grade foundations.
Version 1.2.4b - 06.27.2019
- Corrected the code for raising and logging exceptions.
Version 1.2.5 - 06.29.2019
- Enabled the "Edit SOG Assembly" function/menu for polygon slab-on-grade foundations.
- Enabled the "Edit SOG Outline" function for polygon slab-on-grade foundations.
The ability to edit the outline of polygon shaped foundation is fairly important not only for this plugin but also for the complex roof module of the Truss plugin.  I will be moving back to the Truss plugin this next week to continue my work on the complex roof module.
Version 1.2.5b - 07.01.2019
- Enabled the "Edit Slab Assembly" function/menu for rectangular slab foundations.
- Enabled the "Edit Slab Assembly" function/menu for polygon slab foundations.
- Enabled the "Edit Slab Outline" function for polygon slab foundations.
Version 1.2.6 - 07.03.2019
- Enabled the "Edit Stemwall Assembly" function/menu for rectangular stemwall foundations.
- Enabled the "Edit Stemwall Assembly" function/menu for polygon stemwall foundations.
- Enabled the "Edit Stemwall Outline" function for polygon stemwall foundations.
All of the current features of the foundation plugin are now fully parametric.  However, I do need to introduce a new system for handling stepped foundations and internal strip footings for both slab-on-grade and stemwall foundations.
